[petsc-dev] metis config error on XT4
Wed Nov 30 21:31:01 CST 2011
On Nov 30, 2011, at 6:34 PM, Matthew Knepley wrote:
> On Wed, Nov 30, 2011 at 4:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 30, 2011, at 4:44 PM, Jed Brown wrote:
> > On Wed, Nov 30, 2011 at 16:40, Jack Poulson <jack.poulson at gmail.com> wrote:
> > No, but perhaps I should. My understanding is that those lines only need to be changed when ParMetis is included as a subproject, as they seem to have configured the build system to use relative paths.
> > That's a misuse of CMake. Normally you build from a separate build directory (so that you can clean reliably and independently between configurations). That ParMetis misuses CMake by default isn't an excuse for not allowing it to be used properly.
>  A well designed buildsystem would not allow itself to be misused.
> I am adding code to BuildSystem to electrocute users who try to screw with it.
   Just put a time bomb in Sean's MCS east.
   Barry
>    Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
