[petsc-dev] metis config error on XT4
Jed Brown
jedbrown at mcs.anl.gov
Wed Nov 30 16:44:02 CST 2011
On Wed, Nov 30, 2011 at 16:40, Jack Poulson <jack.poulson at gmail.com> wrote:
> No, but perhaps I should. My understanding is that those lines only need
> to be changed when ParMetis is included as a subproject, as they seem to
> have configured the build system to use relative paths.
That's a misuse of CMake. Normally you build from a separate build
directory (so that you can clean reliably and independently between
configurations). That ParMetis misuses CMake by default isn't an excuse for
not allowing it to be used properly.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111130/2925a839/attachment.html>
