[petsc-dev] Seeking Advice on Petsc Preconditioners to Try
Wed Nov 30 07:15:35 CST 2011
On Wed, Nov 30, 2011 at 12:41 AM, Dave Nystrom <dnystrom1 at comcast.net>wrote:
> I have a linear system in a code that I have interfaced to petsc that is
> taking about 80 percent of the run time per timestep.  This linear system
> is
> a symmetric block banded matrix where the blocks are 2x2.  The matrix looks
> as follows:
>  1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
> 1X X                     Y Y Y
> 2X X X                     Y Y Y
> 3  X X X                     Y Y Y
> 4    X X X                     Y Y Y
> 5      X X X                     Y Y Y
> 6        X X X                     Y Y Y
> 7          X X X                     Y Y Y
> 8            X X X                     Y Y Y
> 9              X X X                     Y Y Y
> 0                X X X                     Y Y Y
> 1                  X X X                     Y Y Y
> 2                    X X X                     Y Y Y
> 3Z                     X X X                     Y Y Y
> 4Z Z                     X X X                     Y Y Y
> 5Z Z Z                     X X X                     Y Y Y
> 6  Z Z Z                     X X X                     Y Y Y
> 7    Z Z Z                     X X X                     Y Y Y
> 8      Z Z Z                     X X X                     Y Y Y
> 9        Z Z Z                     X X X                     Y Y Y
> 0          Z Z Z                     X X X                     Y Y Y
> So in my diagram above, X, Y and Z are 2x2 blocks.  The symmetry of the
> matrix requires that X_ij = transpose(X_ji) and Y_ij = transpose(Z_ji).  So
> far, I have just input this matrix to petsc without indicating that it was
> block banded with 2x2 blocks.  I have also not told petsc that the matrix
> is
> symmetric.  And I have allowed petsc to decide the best way to store the
> matrix.
> I can solve this linear system over the course of a run using -ksp_type
> preonly -pc_type lu.  But that will not scale very well to larger problems
> that I want to solve.  I can also solve this system over the course of a
> run
> using -ksp_type cg -pc_type jacobi -vec_type cusp -mat_type aijcusp.
> However, over the course of a run, the iteration count ranges from 771 to
> 47300.  I have also tried sacusp, ainvcusp, sacusppoly, ilu(k) and icc(k)
> with k=0.  The sacusppoly preconditioner fails because of a thrust error
> related to an invalid device pointer, if I am remembering correctly.  I
> reported this problem to petsc-maint a while back and have also reported it
> for the cusp bugtracker.  But it does not appear that anyone has really
> looked into the bug.  For the other preconditioners of sacusp, ilu(k) and
> icc(k), they do not result in convergence to a solution and the runs fail.
All preconditioners are custom. Have you done a literature search for PCs
known to work for this problem? Can yu say anything about the spectrum of
the
operator? conditioning? what is the principal symbol (if its a PDE)? The
pattern
is not enough to recommend a PC.
   Matt
> I'm wondering if there are suggestions of other preconditioners in petsc
> that
> I should try.  The only third party package that I have tried is the
> txpetscgpu package.  I have not tried hypre or any of the multigrid
> preconditioners yet.  I'm not sure how difficult it is to try those
> packages.  Anyway, so far I have not found a preconditioner available in
> petsc that provides a robust solution to this problem and would be
> interested
> in any suggestions that anyone might have of things to try.
> I'd be happy to provide additional info and am planning on packaging up a
> couple of examples of the matrix and rhs for people I am interacting with
> at
> Tech-X and EMPhotonics.  So I'd be happy to provide the matrix examples for
> this forum as well if anyone wants a copy.
> Thanks,
> Dave
> Dave Nystrom
> phone: 505-661-9943 (home office)
>       505-662-6893 (home)
> skype: dave.nystrom76
> email: dnystrom1 at comcast.net
> smail: 219 Loma del Escolar
>       Los Alamos, NM 87544
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111130/36b1dd3a/attachment.html>
