[petsc-dev] Performance of Petsc Cholesky vs LU
Jed Brown
jedbrown at mcs.anl.gov
Wed Nov 30 00:10:09 CST 2011
On Tue, Nov 29, 2011 at 23:53, Dave Nystrom <dnystrom1 at comcast.net> wrote:
> I have a resistive mhd code that I have recently interfaced to petsc which
> has 7 linear solves that are all symmetric. I recently tried using
> -pc_type
> cholesky -ksp_type preonly for a run and found that it was taking about 6
> times as long per linear solve as when I was using -pc_type lu -ksp_type
> preonly.
Try -pc_factor_mat_ordering_type nd
> I was wondering if that was reasonable behavior. I would not have
> thought that using a cholesky direct solve would take longer than an LU
> direct solve in petsc for the serial case and was hoping it would be
> faster.
> Does this behavior seem reasonable?
Try this:
-pc_type cholesky -pc_factor_mat_ordering_type nd
Barry, why is natural ordering still the default for Cholesky? It is so
slow that it is worthless.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111130/a246be56/attachment.html>
