[petsc-dev] Generality of VecScatter
Tue Nov 29 12:49:26 CST 2011
On Tue, Nov 29, 2011 at 12:40, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  The very first google hit for "pause instruction spin loop"
This is documentation for the first chip to use it. They are asserting that
it does not cause illegal-opcode exceptions for prior chips, so it is valid
to use unconditionally, even in software that needs to run on older chips.
I think this is clear from context (certainly if you had been reading the
documented instead of skipping to the end), but it could have been more
explicit.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111129/1a2a70ea/attachment.html>
