[petsc-dev] programming model for PETSc
Matthew Knepley
knepley at gmail.com
Sat Nov 26 12:34:44 CST 2011
On Sat, Nov 26, 2011 at 12:07 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Nov 25, 2011 at 16:48, Matthew Knepley <knepley at gmail.com> wrote:
>> Synopsis of what I said before to elicit comment:
>> 1) I think the only thing we can learn from Brook, CUDA, OpenCL is that
>> you identify threads by a grid ID.
>> 2) Things like BLAS are so easy that you can move up to the streaming
>> model, but this does not work for
>> - FD and FEM residual evaluation (Jed has an FD example with Aron, SNES
>> ex52 is my FEM example)
>> - FD and FEM Jacobian evaluation
> I think these are also probably too simple. Discontinuous Galerkin with
> overlapped flux computations and interior integration would be a somewhat
> better model problem. Nonlinear Gauss-Seidel in a multigrid context would
> be another.
I do not see DG a fundamentally different.
>> 3) If you look at ex52 I do a "thread transposition" meaning threads
>> start working on different areas of
>> memory which looks like a transpose on a 2D grid. I can do this using
>> shared memory for the vector group.
>> The API is very simple. Give grid indices to the thread, and its done in
>> CUDA and OpenCL essentially the
>> same way.
> As is, this seems to assume a flat memory model and the memory access only
> appears in how the kernel uses threadIdx to determine what memory to
> operate on. If we could say something about this up-front, then the library
> could schedule tasks relative to memory and perhaps handle some updates for
> distributed memory.
My first rule would be, never assume library intelligence. So we make it
possible to give a schedule for kernels, but initially there is
no scheduling code. It is user input, with a dumb default. The flat memory
is the thread shared memory, and everything else is messages.
> Can we have a way to specify the required memory access before launching
> the kernels?
This is exactly what Victor's thing is about
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111126/f9846e03/attachment.html>
