[petsc-dev] Generality of VecScatter
Fri Nov 25 20:13:21 CST 2011
On Fri, Nov 25, 2011 at 20:06, Mark F. Adams <mark.adams at columbia.edu>wrote:
> MIS is straightforward. To define the parallel graph, let's say that
> ghosting processes have (owner rank, index) of neighbors. An owned point is
> only a candidate for selection if all neighbors have the same rank or
> smaller (according to Rule 2 of your paper).
> while (candidates remain):
>     forall v in owned_candidates with neighbor ranks smaller than p:
> This is not quite right, and I want to see how complex or cumbersome this
> one sided model will get when you get all the details in.
> You could say loop:
> for all owned_candidates v
>  for all neighbors q of v
>    if q is selected
>       delete v
>       skip v
>    else if q.proc > myproc and q is not deleted
>       skip v
>    endif
>  end for
>  if not skip v then
>    select v
>    delete all q
>    broadcast v status ????
Why broadcast the single value immediately? I figured that we would just
store the status until we are done with what we can do locally, then we'll
do reduce-and-broadcast and move on to the next round.
>  endif
> end for
> reduce all status to owners ???
Yeah, we reduce the status from the local spaces (which may have marked a
point as deleted), then broadcast. The communication graph is stored on the
local side.
> I thought in your one-sided model you could not broadcast, or push data.
>  You can only pull data and only want to pull data.  But you have a
> broadcast???
Remember that my first primitive was "broadcast", which is essentially
global-to-local. The map is as a local-to-global map and the "get" is
initiated at the local space.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111125/b589fb7a/attachment.html>
