[petsc-dev] Generality of VecScatter
Jed Brown
jedbrown at mcs.anl.gov
Thu Nov 24 16:10:46 CST 2011
On Thu, Nov 24, 2011 at 16:01, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Yes, but they can only get access to that shared variable one at a time:
> first get's it, then second get's it, then third gets, .... Ok for a couple
> of cores but not for dozens.
> Take a look at src/sys/objects/pthread.c for the various ways we have
> coded for "waking" the threads. Maybe I am missing something but this is
> the best Kerry and I could figure out.
What exactly should I be looking at? Can't you have all the threads spin on
a normal shared variable (not a mutex) that is only written by the thread
that needs to spark them? Or use a fetch-and-add atomic if you want to keep
track of how many are running or limit the number? The latter could use a
tree to get logarithmic cost, but if they are stored next to each other,
you would still have O(P) cache invalidations.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111124/d8e03061/attachment.html>
