[petsc-dev] Generality of VecScatter
Jed Brown
jedbrown at mcs.anl.gov
Wed Nov 23 18:57:53 CST 2011
On Wed, Nov 23, 2011 at 18:48, Dmitry Karpeev <karpeev at gmail.com> wrote:
> > I wonder if we can express all useful communication with a more
> restrictive interface similar to a local-to-global map (but mapping between
> any vectors) where one side (typically called "local", but doesn't need to
> actually be a local Vec) has at most one edge.
> That would disallow accumulating a MAX "locally".
I don't know what you mean. Say we have a scatter from X (sometimes
"local") to Y (sometimes "global"). One way to describe my communication
graph is as a single-valued function on X (containing either the index into
Y or NULL). I'm asking whether the single-valued constraint is too
restrictive for some important use case.
The primitives I can readily provide are
broadcast from Y to X
reduce values on X into Y (min, max, sum, replace, etc)
gather values on X into arrays for each point in Y (in some ordering, rank
ordering if you like)
scatter values in arrays for each point in Y to the point in X
These latter two involve a data structure that is as big as the number of
sharing processes (because that is explicitly being requested), but are
still implemented where the owner of that point in Y has no knowledge of
which processes it is communicating with. With the capability of hardware
RMA, this can actually be more efficient than if the two-sided graph was
available (and it's less code and fewer data structures).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111123/a36f0f59/attachment.html>
