[petsc-dev] uni
Wed Nov 23 17:10:26 CST 2011
On Nov 23, 2011, at 3:14 PM, Mark F. Adams wrote:
> I fixed my code error with valgrind and now I see the same thing (appended) as before (eg, valgrind does not seem to help).
> I'm suspecting that MatConvert is messed, but I will try not deleting this matrix and see what happens.
> ==69836== Conditional jump or move depends on uninitialised value(s)
> ==69836==    at 0x1E8A5DE: ATL_dgemvT_a1_x1_b0_y1 (in /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib)
> ==69836==
> ==69836==    at 0x1EBAC7A: ATL_dger1_a1_x1_yX (in /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib)
> ==69836==
> [0]
   Yes it pisses me off to no end that Apple got suckered into using that ATLAS crap and it is buggy with basic memory errors and Jack doesn't give a shit.
    It you can tell us how to run a code (or push an example and tell use it) that reproduces this we can also debug it to see what the problem is.
   Barry
> On Nov 23, 2011, at 2:01 PM, Barry Smith wrote:
>> On Nov 23, 2011, at 10:31 AM, Mark F. Adams wrote:
>>> Yep, need to keep the extra include with uni, but not the lib anymore.
>>> Now I get this error, any ideas?  I need a uni regression test apparently.
>>   After you do the "make all test" on PETSc do "make alltests" and it should run all the tests that run on one process.
>>   Something is wrong with your reference counting likely here. Does this work with --with-debugging=0? I would run debug version with valgrind first. Then debug version in debugger.
>>  Barry
>>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>>> [0]PETSC ERROR: Corrupt argument:
>>> see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind!
>>> [0]PETSC ERROR: Inner MPI_Comm does not have expected reference to outer comm!
>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>> [0]PETSC ERROR: Petsc Development HG revision: 3dda30872eeec1a2ea5c130f267935c5e0b2534a  HG Date: Mon Nov 21 11:19:39 2011 -0800
>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> [0]PETSC ERROR: ./viscousTensorSolve2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.ex on a arch-maco named madams-macbk-3.local by markadams Wed Nov 23 11:25:30 2011
>>> [0]PETSC ERROR: Libraries linked from /Users/markadams/Codes/petsc-dev/arch-macosx-gnu-seq/lib
>>> [0]PETSC ERROR: Configure run at Tue Nov 22 12:41:46 2011
>>> [0]PETSC ERROR: Configure options CXX=/sw/lib/gcc4.4/bin/g++-4 CC=/sw/lib/gcc4.4/bin/gcc-4 FC=/sw/lib/gcc4.4/bin/gfortran --with-x=0 --with-clanguage=c++ --with-debugging=0 --with-mpi=0 PETSC_ARCH=arch-macosx-gnu-seq
>>> [0]PETSC ERROR: Petsc_DelComm() line 448 in /Users/markadams/Codes/petsc-dev/src/sys/objects/pinit.c
>>> [0]PETSC ERROR: MPI_Comm does not have tag/name counter nor does it have inner MPI_Comm!
>>> [0]PETSC ERROR: PetscCommDestroy() line 229 in /Users/markadams/Codes/petsc-dev/src/sys/objects/tagm.c
>>> [0]PETSC ERROR: PetscHeaderDestroy_Private() line 110 in /Users/markadams/Codes/petsc-dev/src/sys/objects/inherit.c
>>> [0]PETSC ERROR: MatDestroy() line 1045 in /Users/markadams/Codes/petsc-dev/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: partitionLevel() line 347 in /Users/markadams/Codes/petsc-dev/src/ksp/pc/impls/gamg/gamg.c
>>> [0]PETSC ERROR: PCSetUp_GAMG() line 599 in /Users/markadams/Codes/petsc-dev/src/ksp/pc/impls/gamg/gamg.c
>>> [0]PETSC ERROR: PCSetUp() line 819 in /Users/markadams/Codes/petsc-dev/src/ksp/pc/interface/precon.c
>>> [0]PETSC ERROR: KSPSetUp() line 261 in /Users/markadams/Codes/petsc-dev/src/ksp/ksp/interface/itfunc.c
>>> [0]PETSC ERROR: solveprivate() line 191 in "unknowndirectory/"PetscLinearSolverI.H
>>> On Nov 22, 2011, at 3:19 PM, Barry Smith wrote:
>>>> You have som other MPI include file hanging around that is getting intercepted before the MPI Uni one.
>>>> Barry
>>>> On Nov 22, 2011, at 12:00 PM, Mark F. Adams wrote:
>>>>> Scorched earth did not work:
>>>>> "VecCreate(ompi_communicator_t*, _p_Vec**)", referenced from:
>>>>>  PetscLinearSolver<LevelData<FArrayBox> >::solveprivate(LevelData<FArrayBox>&, LevelData<FArrayBox> const&) in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o)
>>>>> "_ompi_mpi_comm_self", referenced from:
>>>>>  _ompi_mpi_comm_self$non_lazy_ptr in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o)
>>>>> <configure.log.gz>
>>>>> On Nov 22, 2011, at 11:47 AM, Satish Balay wrote:
>>>>>> Something is strange.
>>>>>> I'll suggeset
>>>>>> rm -rf externalpackages arch-macosx-gnu-seq
>>>>>> and then doing a fresh build.
>>>>>> And then verifying the build with 'make test'
>>>>>> If 'make test' works - and the application build is not working- I'd
>>>>>> like to see the complete compile log thats producing this error.
>>>>>> wrt libmpiuni.a - all the relavent stuff is added to libpetsc.a and a separate
>>>>>> libmpiuni.a is not created.
>>>>>> Satish
>>>>>> On Tue, 22 Nov 2011, Mark F. Adams wrote:
>>>>>>> I'm trying to build a non MPI code and get this error:
>>>>>>> Undefined symbols:
>>>>>>> (maybe you meant: _ompi_mpi_comm_self$non_lazy_ptr)
>>>>>>> In the past I have linked libmpiuni.a but that did not seem to get created.  Did libmpiuni.a go away or did my make fail ...
>>>>>>> Mark
