[petsc-dev] uni
    Matthew Knepley
    knepley at gmail.com
    Tue Nov 22 10:58:01 CST 2011
Before you go scorched earth on your externalpackages, did you turn on any
packages? Some require
MPI and if they are already built when you switch to MPIUNI we could have
forgotten a check. I would
leave off all packages to start. Then we can locate this error.
   Matt
On Tue, Nov 22, 2011 at 10:39 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> I'm trying to build a non MPI code and get this error:
> Undefined symbols:
>  "_ompi_mpi_comm_self", referenced from:
>      _ompi_mpi_comm_self$non_lazy_ptr in
> libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o)
>     (maybe you meant: _ompi_mpi_comm_self$non_lazy_ptr)
> In the past I have linked libmpiuni.a but that did not seem to get
> created.  Did libmpiuni.a go away or did my make fail ...
> Mark
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111122/81ca73df/attachment.html>
