[petsc-dev] CUDA 4.1 RC1
John Fettig john.fettig at gmail.com
Fri Nov 18 14:23:54 CST 2011
The good news is it builds.  The bad news is that it doesn't function
properly.  This same code works fine with cuda 4.0, so I'll have to dig
deeper to figure out where it is going wrong.  I tried running one of the
examples and it worked with sacusp, so perhaps something isn't working
right in my code.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Floating point exception!
[0]PETSC ERROR: Infinite or not-a-number generated in norm!
[0]PETSC ERROR:
[0]PETSC ERROR:
[0]PETSC ERROR: VecNorm() line 167 in src/vec/vec/interface/rvector.c
[0]PETSC ERROR: KSPSolve_CG() line 140 in src/ksp/ksp/impls/cg/cg.c
[0]PETSC ERROR: KSPSolve() line 429 in src/ksp/ksp/interface/itfunc.c
John
On Wed, Nov 16, 2011 at 4:36 PM, Daniel Lowell <redratio1 at gmail.com> wrote:
> Not yet. But I'm considering it.
> On Wed, Nov 16, 2011 at 3:33 PM, John Fettig <john.fettig at gmail.com>wrote:
>> Has anybody tried compiling petsc-dev using CUDA 4.1?  I'm just wondering
>> if I should bother trying.
>> Thanks,
>> John
> Daniel Lowell
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111118/7e862f9b/attachment.html>
