[petsc-dev] removing DMRefine/CoarsenHierarchy?
Sun Nov 13 22:11:24 CST 2011
On Nov 13, 2011, at 8:57 PM, Jed Brown wrote:
> On Sun, Nov 13, 2011 at 18:58, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Does anyone object if I remove DMRefine/CoarsenHierarchy() and just have DMRefine/Coarsen() take a number of levels argument?
> So: remove DMRefine/Coarsen and then rename the Hierarchy versions? Sounds fine to me, you can just pass one level.
> The comm argument would be removed from the calling sequence, doesn't work anyways.
> The need to use the same communicator on coarse grids is pretty limiting, in my opinion. It may be tricky to implement, but I'm not sure we should remove it from the interface.
  It can be passed in some other way.
   Barry
