[petsc-dev] checking if a vector is ghosted
    Matthew Knepley
    knepley at gmail.com
    Tue Nov  8 14:05:01 CST 2011
On Tue, Nov 8, 2011 at 8:02 PM, mspieg <mspieg at ldeo.columbia.edu> wrote:
> Nevermind…I should always think for 10 more minutes before I type…
> Just want to check that the following is a kosher use of the return error
> handler
>    bool _is_ghosted = true;
>    PetscErrorCode ierr;
>    PetscPushErrorHandler(PetscReturnErrorHandler,PETSC_NULL);
>    ierr= VecGhostGetLocalForm(*x, x_ghosted.get());
>    if (ierr != 0 )
>      _is_ghosted = false;
>    PetscPopErrorHandler();
Do you need to mess with the error handler?
   Matt
> cheers
> marc
> On Nov 8, 2011, at 2:06 PM, mspieg wrote:
> > Hi All,
> >   is there a clean way to test if a vector is ghosted (i.e created with
> VecCreateGhost…) without trying to call VecGhostGetLocalForm and throwing
> an exception?
> > In 3.1 I got around this using  PetscExceptonTry1  but apparently in 3.2
> and dev  PetscException… is "too cool for school" ;^)
> > One possible  simple fix would be something like
> > PetscError VecGhostIsGhosted(Vec g, PetscBool isghosted)
> > and just return the results of  the logical tests in
> VecGhostGetLocalForm without throwing an error.
> > (alternatively, I suppose I could mess with the ErrorHandlers but that
> seems like overkill for this).
> > Let me know what might work.
> > cheers
> > marc
> > Marc Spiegelman
> > Lamont-Doherty Earth Observatory
> > Dept. of Applied Physics/Applied Math
> > Columbia University
> > http://www.ldeo.columbia.edu/~mspieg
> > tel: 845 704 2323 (SkypeIn)
> Marc Spiegelman
> Columbia University
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111108/7509d6c1/attachment.html>
