[petsc-dev] Stupid BuildSystem question: How do I force rebuild of a downloaded package?
Satish Balay
balay at mcs.anl.gov
Mon Nov 7 14:26:00 CST 2011
On Mon, 7 Nov 2011, Richard Tran Mills wrote:
> Hi Folks,
> I am trying to test the changes I have made to the PLAPACKR32-hg package
> before pushing them back up and asking Satish to rebuild the tarball. I
> guessed that I could do this by deleting
> $PETSC_DIR/externalpackages/PLAPACKR32-hg and
> $PETSC_DIR/$PETSC_ARCH/lib/libPLAPACK.a, pointing the download path to my
> local tarball, and running configure again. I get the following:
> Now, my question is: Why does BuildSystem think that it doesn't have to
> rebuild PLAPACK? I have deleted
> /home/rmills/proj/petsc-dev/ubuntu-gnu_g/lib/libPLAPACK.a. Configure tries to
> link with that, anyway, and then eventually gives up and tells me that the
> downloaded PLAPACK can't be used. Shouldn't it *not* do that since this file
> doesn't exist?
do: rm -f /home/rmills/proj/petsc-dev/ubuntu-gnu_g/conf/PLAPACK
configure creates a config file for each pakage - and stashes it at
this location. If configure is reinvoked - it checks the previously
created conf file [i.e
/home/rmills/proj/petsc-dev/ubuntu-gnu_g/conf/PLAPACK] and sees if it
matches the currently generated one [to see if all compiler, mpi etc
options are the same]. If they match - it decides not to rebuild that
package.
Satish
> I can work around this by deleting my $PETSC_DIR/$PETSC_ARCH directory and
> rebuilding everything, but this can take a long time if I have a lot of
> downloaded packages.
> --Richard
