[petsc-dev] Bordered systems and low-rank corrections
Fri Nov 4 20:45:05 CDT 2011
On Fri, Nov 4, 2011 at 13:55, Mark F. Adams <mark.adams at columbia.edu> wrote:
> The two actually look very similar.  The community that I learned Uzawa
> from is very familiar with Sherman-Morrison.   Uzawa might in fact be an
> iterative S-M ... the wikapedia page does not explain how to recover the
> solution Y and does not accommodate a non-zero RHS for the constraint
> equations.  Both of which you'd want to do to be general.
Well, the Schur complement is in the other direction. Are you talking about
the Uzawa or Sherman-Morrison page? It's easy enough either way.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111104/0500ee15/attachment.html>
