[petsc-dev] Questions about	MatMatTransposeMult/MatMatMultTranspose
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Nov  1 11:34:57 CDT 2011
  I think Jed wants to set these all up to use the dispatch on type table, rather than attaching the methods to the objects.
On Nov 1, 2011, at 8:09 AM, Dmitry Karpeev wrote:
> Is there any reason that there isn't dual dispatch support for these routines like there is for MatMatMult?
> If there is no particular reason, I would like to add it, largely for the same reasons I'd like symmetric
> dual dispatch for MatMatMult: the ability to add new implementations without screwing around with all of the
> constructors.
> Similar considerations would apply to the MatMat*Symbolic routines, as well as MatPtAP.
> I still maintain that the right way to handle these is triple dispatch that depends on the type of the output
> Mat as well, but that would only matter in a handful of corner cases.
> And a minor question: wouldn't it be better to name these two functions MatTransposeMatMult and MatMatTransposeMult
> respectively, so that the "Transpose" operation sits next to the matrix it operates on?
    A' * B and A * B' ? Sounds reasonable.
   Barry
> Dmitry.
