[petsc-dev] Potential memory issue with block jacobi preconditioner
fabien delalondre delalf at scorec.rpi.edu
Tue May 31 15:31:14 CDT 2011
Hi All,
I am trying to solve a problem for which we have a couple of 2D planes
located along the toroidal direction. We are trying to use the block jacobi
preconditioner where a block is computed for each 2D plane.
When we use a number of blocks that is equal to the number of planes, the
execution fails with the following message: "glibc detected" (both on
PPPL (large
memory Symetrical MultiProcessing (SMP) system with 80 CPUs and 440 GB of
memory) and NERSC/Hopper machines). If we run the same test case with number
of blocks = 0.5 (number of planes), it seems to run fine (although it's
obviously slow). I ran Totalview/memscape on it and did not find anything
useful so far (no memory leak or memory corruption detected). At this point
I am not sure if the problem is on the petsc side or not. I am now trying to
recompile everything on our local machines at scorec to use valgrind.
The version I used on hopper is the petsc-dev version as of 031011 compiled
with mumps, hypre, scalapack, parmetis, superlu_dist, parmetis. The used
compiler is the default compiler on hopper (pgi)
Please let me know if you have any idea that could help me solving this
problem.
Thank you.
Fabien
Fabien Delalondre, PhD.
Senior Research Associate, Scientific Computation Research Center (SCOREC).
Rensselaer Polytechnic Institute (RPI), Troy, NY.
Email: delalf at scorec.rpi.edu, Phone: (518)-276-8045
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110531/c5f29866/attachment.html>
