[petsc-dev] cmakeboot.py is a total disaster needs fixing or	removal
    Barry Smith
    bsmith at mcs.anl.gov
    Mon May 23 16:50:45 CDT 2011
  Satish,
    I deleted this from the mailing list before it was sent out. Hence it should be ignored and not visible to anyone
   Barry
On May 23, 2011, at 4:47 PM, Satish Balay wrote:
> Barry,
> Does --with-cmake=0 workarround this?
> Satish
> On Mon, 23 May 2011, Barry Smith wrote:
>>   Jed,
>>    I can no longer configure!
>>    You move a bunch of stuff that has nothing to do with cmake into cmakeboot.py  for example    self.make          = self.framework.require('config.programs',        None)
>> now if your silly cmakeboot stuff doesn't work then variables like OMAKE are never defined in the generated petscvariables file and so nothing can get built. Pisses me off, it is fine to support cmake but don't make it the goddamn center of PETSc.
>>   I am stuck without PETSc because I don't have a clue why this is happening.
>>   Barry
>> [see attached file: configure.log]
