[petsc-dev] attaching field information to PetscLayout?
    Jed Brown
    jed at 59A2.org
    Mon May 16 18:02:41 CDT 2011
On Tue, May 17, 2011 at 00:57, Matthew Knepley <knepley at gmail.com> wrote:
> For FEM stuff (like mixed elements, higher order, complicated bases), I
> need layout information that maps
>     mesh piece ---> (size, offset)
> I made a separate structure to contain this info, but it sounds like this
> suped-up PetscLayout could contain it
> instead. Is that feasible?
How are you identifying "mesh piece"? This appears to be basically another
step removed (but in the same spirit of) the ISLocalToGlobalMapping.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110517/a837af91/attachment.html>
