[petsc-dev] attaching field information to PetscLayout?
Jed Brown
jed at 59A2.org
Sun May 15 13:55:49 CDT 2011
On Sun, May 15, 2011 at 05:33, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> Would it be dangerous to be adding fields to a PetscLayout shared by
> many Vecs/Mats (hence, PCs)?
I think PetscLayout should be strictly immutable after PetscLayoutSetUp().
Yes, in fact, a field, at least in my mind, is more than just
> combinatorial information (IS), and might
> involve some linear-algebraic information (e.g., if getting the
> corresponding subvec or updating
> the containing vec requires a linear transformation).
I think this might be snowballing beyond what is reasonable to handle at
this level. Someone might say that converting [Density,Momentum,Energy] to
[Pressure,Velocity,Temperature] has some semantic meaning to them and they
want to tell PETSc about it, but it may be a hard sell to demonstrate that
an equation of state belongs in PetscLayout. This example isn't even
contrived though: the relevant Schur complement for preconditioning low-Mach
Euler is a parabolic operator in the pressure space, despite the fact that
pressure is not a conserved variable (thus not explicitly present in the
original system).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110515/615d6cc5/attachment.html>
