[petsc-dev] attaching field information to PetscLayout?
Dmitry Karpeev karpeev at mcs.anl.gov
Sat May 14 16:33:32 CDT 2011
On Sat, May 14, 2011 at 3:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On May 14, 2011, at 3:31 PM, Dmitry Karpeev wrote:
>> On Sat, May 14, 2011 at 3:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> On May 14, 2011, at 3:09 PM, Jed Brown wrote:
>>>> On Sat, May 14, 2011 at 21:47, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>>>> Can these split ISs have communicators different from that of
>>>> PetscLayout (this is something I use in GASM,
>>>> for example)?
>>>> I guess I always thought of the field information in PetscLayout as having semantic meaning to the user. I also thought these ISs would be strictly non-overlapping and addressing locally owned values.
>>> Dmitry asked: What will be the meaning of overlapping splits?
>>> Matt wrote:  boundary conditions (if you want).
>>> Jed wrote later:  think that has different semantic meaning and thus deserves a different mechanism. I don't know whether it belongs in PetscLayout, but I think it is a different beast from defining "fields" that have semantic meaning to the user.
>> Via Vec/MatSetValuesLocal?  I would agree with that.
>> What I don't like about that is that now there will be two different
>> ways of treating splits that happen to be nonoverlapping:
>> via some clever XXXSetValuesLocal and via the nonoverlapping splits
>> mechanism inside PetscLayout.
>   This is a good observation, rather than putting the localtoglobal mappings onto Vecs and Mats we could put them onto the PetscLayout inside the Vec/Mat, this would simplify the current code a bit and get things like MatGetVecs() to properly pass local to global information to the created vectors. So for example we could have something like
> typedef struct _n_PetscLayout* PetscLayout;
> struct _n_PetscLayout{
>  MPI_Comm  comm;
>  PetscInt  n,N;         /* local, global vector size */
>  PetscInt  rstart,rend; /* local start, local end + 1 */
>  PetscInt  *range;      /* the offset of each processor */
>  PetscInt  bs;          /* number of elements in each block (generally for multi-component problems) Do NOT multiply above numbers by bs */
>  PetscInt  refcnt;      /* MPI Vecs obtained with VecDuplicate() and from MatGetVecs() reuse map of input object */
>  PetscInt nfields; IS *fields;
>  IS localtoglobalmapping,blocklocaltoglobalmapping.
>  USER INFO LIKE boundary condition locations;
>   We could put the localtoglobalmappings into the PetscLayout independent of the other changes we've been discussing.
That would also be convenient if a Vec and a Mat shared the layout
(Mat's cmap), because then they automatically have
compatible splits and/or localtoglobalmappings.  Recently, however, I
became convinced that l2gmappings, as they are now,
are not adequate for some more advanced tasks, such as splitting of
matrices/vectors into overlapping pieces. So, it would
be nice to have a more general object in place of l2gmappings.
SAMapping is supposed to be it, but it is still in flux and largely
untested. One problem with this is that manipulation of local pieces
of a matrix/vector can carry linear-algebraic information
(e.g., weights), which might not belong in PetscLayout, which at the
moment is purely combinatorial.
I suppose this is just a comment at the moment, rather than a suggestion.
Dmitry.
>   Barry
>> Dmitry.
>>> Barry responds: we could require non-overlapping splits but I am not sure if that is necessary or desirable. For example, the first IS might denote velocity variables, the second IS might denote pressure variables the third IS might denote locations with fixed boundary conditions. All of these things have "semantic meaning" to the users. Only some of them may have meaning to the PCFieldSplit. If we could use the same mechanism for all of them that might be better than having different mechanisms for "marking" different "meanings".
>>>   Barry
>>>> In that context, there is no particular disadvantage to always using global ISs, and I think it would help keep the code simple. If you are going to solve part of the problem on a sub-communicator, you can define that subcomm as all those processes that have non-empty local part in the IS. If you have a huge number of splits (such that individual splits on longer have semantic meaning), then I think it is a different purpose.
