[petsc-dev] Question re parallel sparse Matrix-vector / KSP solvers
David Henty d.henty at epcc.ed.ac.uk
Fri May 13 10:49:57 CDT 2011
I see in the example for how to solve A.x_i = b_i (ie multiple
right-hand-sides for the same matrix), it simply loops over multiple
separate KSP calls.
Wouldn't there be some benefit in having a matrix-vector routine that
computed y_i = A.x_i for multiple "i" values? The parallel overhead
comes from communicating the off-process x values. As this is probably
latency dominated (especially as we go to many processes), the comms
cost of doing the communications would rise quite slowly for additional
vectors. Likewise, the cache utilisation of the sparse A matrix entries
would be helped by doing sevefal multiplications at once.
Has this already been implemented, or maybe in the pipleline? Or am I
somehow missing the point ...
Thanks!
David
Dr David Henty                        EPCC, The University of Edinburgh
HPC Training and Support              Edinburgh EH9 3JZ, UK
d.henty at epcc.ed.ac.uk                 Tel: +44 (0)131 650 5960
http://www.epcc.ed.ac.uk/~dsh/        Fax: +44 (0)131 650 6555
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
