[petsc-dev] autogeneration of petscconf.h for C, C++ and Fortran
Fri May 13 08:16:10 CDT 2011
On May 13, 2011, at 3:58 AM, Jed Brown wrote:
> On Fri, May 13, 2011 at 04:43, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On occasion the same options in petscconf.h don't work for both C and C++ compilers, for example for __intel_fast_memcpy().
> This is just insane, but I thought the compiler automatically expanded normal memcpy to __intel_fast_memcpy. I just checked and my Intel C and C++ compilers (versions 10 and 11) do this automatically at -O2 and above. Should PETSc ever be calling it directly?
   I have removed the use of the __intel_fast functions from the PETSc source. Would have saved us tons of pain with that damn problem if I listened to you years ago.
>  Should we instead generate three files one for each language?
> If it's really necessary, why not put both in the same header guarded by #ifdef __cplusplus ?
  Why? Since we have complete control of the process why put in ugly #ifdef logic? Just put the information into different files.  Use of CPP is an admission that you haven't found a better way to do it :-)
   Barry
