[petsc-dev] CMake broken
    Satish Balay
    balay at mcs.anl.gov
    Wed May 11 10:46:36 CDT 2011
pushed the change.
satish
On Wed, 11 May 2011, Barry Smith wrote:
>    That is my fault. I messed with that SUBPROCESS file a long time ago and forgot I changed it, then when I put in proper changes I left that bad change.
>     Satish, can you remove the comment of the subprocess stuff and push?
>     Thanks
>     Barry
> On May 11, 2011, at 7:51 AM, Jose E. Roman wrote:
> > CMake build is broken in the latest petsc-dev: cmakeboot does not generate the makefiles.
> > I have made a bisection search and found this changeset in BuildSystem:
> > http://petsc.cs.iit.edu/petsc/BuildSystem/rev/bbad23803405
> > If I uncomment the line USE_SUBPROCESS = 0 in config/Buildsystem/script.py then it works again.
> > Jose
