[petsc-dev] [petsc-maint #72279] PETSc and multigpu
    Victor Minden
    victorminden at gmail.com
    Tue May 10 18:07:23 CDT 2011
I pushed my change to petsc-dev, so hopefully a new pull of the latest
mercurial repository should do it, let me know if not.
Victor L. Minden
Tufts University
School of Engineering
Class of 2012
On Tue, May 10, 2011 at 6:59 PM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
>  Hi Victor,
> Thanks a lot!
> What should we do to get new version?
> Regards,
> Alexander
> On 10.05.2011 02:02, Victor Minden wrote:
> I believe I've resolved this issue.
>  Cheers,
>  Victor
> Victor L. Minden
> Tufts University
> Class of 2012
> On Sun, May 8, 2011 at 5:26 PM, Victor Minden <victorminden at gmail.com>wrote:
>> Barry,
>> I can verify this on breadboard now,
>> with two processes, cuda
>> minden at bb45:~/petsc-dev/src/snes/examples/tutorials$
>> /home/balay/soft/mvapich2-1.5-lucid/bin/mpiexec.hydra -machinefile
>> /home/balay/machinefile -n 2 ./ex47cu -da_grid_x 65535 -log_summary
>> -snes_monitor -ksp_monitor -da_vec_type cusp
>>   0 SNES Function norm 3.906279802209e-03
>>    0 KSP Residual norm 5.994156809227e+00
>>    1 KSP Residual norm 5.927247846249e-05
>>  1 SNES Function norm 3.906225077938e-03
>>    0 KSP Residual norm 5.993813868985e+00
>>    1 KSP Residual norm 5.927575078206e-05
>>  terminate called after throwing an instance of
>> 'thrust::system::system_error'
>>  what():  invalid device pointer
>>  Aborted (signal 6)
>> Without cuda
>>    1 KSP Residual norm 3.538158441448e-04
>>    2 KSP Residual norm 3.124431921666e-04
>>    3 KSP Residual norm 4.109213410989e-06
>>  1 SNES Function norm 7.201017610490e-04
>>    0 KSP Residual norm 3.317803708316e-02
>>    1 KSP Residual norm 2.447380361169e-06
>>    2 KSP Residual norm 2.164193969957e-06
>>    3 KSP Residual norm 2.124317398679e-08
>>  2 SNES Function norm 1.719678934825e-05
>>    0 KSP Residual norm 1.651586453143e-06
>>    1 KSP Residual norm 2.037037536868e-08
>>    2 KSP Residual norm 1.109736798274e-08
>>    3 KSP Residual norm 1.857218772156e-12
>>  3 SNES Function norm 1.159391068583e-09
>>    0 KSP Residual norm 3.116936044619e-11
>>    1 KSP Residual norm 1.366503312678e-12
>>    2 KSP Residual norm 6.598477672192e-13
>>    3 KSP Residual norm 5.306147277879e-17
>>  4 SNES Function norm 2.202297235559e-10
>>  Note the repeated norms when using cuda.  Looks like I'll have to take
>> a closer look at this.
>> -Victor
>> Victor L. Minden
>> Tufts University
>> Class of 2012
>> On Thu, May 5, 2011 at 2:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > Alexander
>> >    Thank you for the sample code; it will be very useful.
>> >    We have run parallel jobs with CUDA where each node has only a single
>> MPI process and uses a single GPU without the crash that you get below. I
>> cannot explain why it would not work in your situation. Do you have access
>> to two nodes each with a GPU so you could try that?
>> >   It is crashing in a delete of a
>> > struct  _p_PetscCUSPIndices {
>> >  CUSPINTARRAYCPU indicesCPU;
>> >  CUSPINTARRAYGPU indicesGPU;
>> > where cusp::array1d<PetscInt,cusp::device_memory>
>> > thus it is crashing after it has completed actually doing the
>> computation. If you run with -snes_monitor -ksp_monitor with and without the
>> -da_vec_type cusp on 2 processes what do you get for output in the two
>> cases? I want to see if it is running correctly on two processes?
>> > Could the crash be due to memory corruption sometime doing the
>> computation?
>> >   Barry
>> > On May 5, 2011, at 3:38 AM, Alexander Grayver wrote:
>> >> Hello!
>> >> We work with petsc-dev branch and ex47cu.cu example. Our platform is
>> >> Intel Quad processor and 8 identical Tesla GPUs. CUDA 3.2 toolkit is
>> >> installed.
>> >> Ideally we would like to make petsc working in a multi-GPU way within
>> >> just one node so that different GPUs could be attached to different
>> >> processes.
>> >> Since it's not possible within current PETSc implementation we created
>> a
>> >> preload library (see LD_PRELOAD for details) for CUBLAS function
>> >> cublasInit().
>> >> When PETSc calls this function our library gets control and we assign
>> >> GPUs according to rank within MPI communicator, then we call original
>> >> cublasInit().
>> >> This preload library is very simple, see petsc_mgpu.c attached.
>> >> This trick makes each process to have its own context and ideally all
>> >> computations should be distributed over several GPUs.
>> >> We managed to build petsc and example (see makefile attached) and we
>> >> tested it as follows:
>> >> [agraiver at tesla-cmc new]$ ./lapexp -da_grid_x 65535 -info >
>> cpu_1process.out
>> >> [agraiver at tesla-cmc new]$ mpirun -np 2 ./lapexp -da_grid_x 65535 -info
>> >> cpu_2processes.out
>> >> [agraiver at tesla-cmc new]$ ./lapexp -da_grid_x 65535 -da_vec_type cusp
>> >> -info > gpu_1process.out
>> >> -da_vec_type cusp -info > gpu_2processes.out
>> >> Everything except last configuration works well. The last one crashes
>> >> with the following exception and callstack:
>> >> [tesla-cmc:15549] *** Process received signal ***
>> >> [tesla-cmc:15549] Signal: Aborted (6)
>> >> [tesla-cmc:15549] Signal code:  (-6)
>> >> [tesla-cmc:15549] [ 0] /lib64/libpthread.so.0() [0x3de540eeb0]
>> >> [tesla-cmc:15549] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x3de50330c5]
>> >> [tesla-cmc:15549] [ 2] /lib64/libc.so.6(abort+0x186) [0x3de5034a76]
>> >> [tesla-cmc:15549] [ 3]
>> /opt/llvm/dragonegg/lib64/libstdc++.so.6(_ZN9__gnu_cxx27__verbose_terminate_handlerEv+0x11d)
>> >> [0x7f0d3530b95d]
>> >> [tesla-cmc:15549] [ 4]
>> >> /opt/llvm/dragonegg/lib64/libstdc++.so.6(+0xb7b76) [0x7f0d35309b76]
>> >> [tesla-cmc:15549] [ 5]
>> >> /opt/llvm/dragonegg/lib64/libstdc++.so.6(+0xb7ba3) [0x7f0d35309ba3]
>> >> [tesla-cmc:15549] [ 6]
>> >> /opt/llvm/dragonegg/lib64/libstdc++.so.6(+0xb7cae) [0x7f0d35309cae]
>> >> [tesla-cmc:15549] [ 7]
>> ./lapexp(_ZN6thrust6detail6device4cuda4freeILj0EEEvNS_10device_ptrIvEE+0x69)
>> >> [0x426320]
>> >> [tesla-cmc:15549] [ 8]
>> ./lapexp(_ZN6thrust6detail6device8dispatch4freeILj0EEEvNS_10device_ptrIvEENS0_21cuda_device_space_tagE+0x2b)
>> >> [0x4258b2]
>> >> [tesla-cmc:15549] [ 9]
>> >> ./lapexp(_ZN6thrust11device_freeENS_10device_ptrIvEE+0x2f) [0x424f78]
>> >> [tesla-cmc:15549] [10]
>> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(_ZN6thrust23device_malloc_allocatorIiE10deallocateENS_10device_ptrIiEEm+0x33)
>> >> [0x7f0d36aeacff]
>> >> [tesla-cmc:15549] [11]
>> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(_ZN6thrust6detail18contiguous_storageIiNS_23device_malloc_allocatorIiEEE10deallocateEv+0x6e)
>> >> [0x7f0d36ae8e78]
>> >> [tesla-cmc:15549] [12]
>> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(_ZN6thrust6detail18contiguous_storageIiNS_23device_malloc_allocatorIiEEED1Ev+0x19)
>> >> [0x7f0d36ae75f7]
>> >> [tesla-cmc:15549] [13]
>> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(_ZN6thrust6detail11vector_baseIiNS_23device_malloc_allocatorIiEEED1Ev+0x52)
>> >> [0x7f0d36ae65f4]
>> >> [tesla-cmc:15549] [14]
>> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(_ZN4cusp7array1dIiN6thrust6detail21cuda_device_space_tagEED1Ev+0x18)
>> >> [0x7f0d36ae5c2e]
>> >> [tesla-cmc:15549] [15]
>> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(_ZN19_p_PetscCUSPIndicesD1Ev+0x1d)
>> [0x7f0d3751e45f]
>> >> [tesla-cmc:15549] [16]
>> >> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(PetscCUSPIndicesDestroy+0x20f)
>> >> [0x7f0d3750c840]
>> >> [tesla-cmc:15549] [17]
>> >> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(VecScatterDestroy_PtoP+0x1bc8)
>> >> [0x7f0d375af8af]
>> >> [tesla-cmc:15549] [18]
>> >> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(VecScatterDestroy+0x586)
>> >> [0x7f0d375e9ddf]
>> >> [tesla-cmc:15549] [19]
>> >> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(MatDestroy_MPIAIJ+0x49f)
>> >> [0x7f0d37191d24]
>> >> [tesla-cmc:15549] [20]
>> >> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(MatDestroy+0x546)
>> [0x7f0d370d54fe]
>> >> [tesla-cmc:15549] [21]
>> >> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(SNESReset+0x5d1)
>> [0x7f0d3746fac3]
>> >> [tesla-cmc:15549] [22]
>> >> /opt/openmpi_gcc-1.4.3/lib/libpetsc.so(SNESDestroy+0x4b8)
>> [0x7f0d37470210]
>> >> [tesla-cmc:15549] [23] ./lapexp(main+0x5ed) [0x420745]
>> >> I've sent all detailed output files for different execution
>> >> configuration listed above as well as configure.log and make.log to
>> >> petsc-maint at mcs.anl.gov hoping that someone could recognize the
>> problem.
>> >> Now we have one node with multi-GPU, but I'm also wondering if someone
>> >> really tested usage of GPU functionality over several nodes with one
>> GPU
>> >> each?
>> >> Regards,
>> >> Alexander
>> >> <petsc_mgpu.c><makefile.txt><configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110510/e04c8178/attachment.html>
