[petsc-dev] two quick questions on Fortran style/includes
Barry Smith
bsmith at mcs.anl.gov
Tue May 10 13:00:15 CDT 2011
Satish,
Please apply this patch.
Thanks
Barry
On May 10, 2011, at 11:46 AM, Ethan Coon wrote:
> 1. Is there a reason that both .F and .F90 examples are in fixed format,
> even though .F90 files should be interpreted as free format? I guess
> the fixed format works for either a fixed/free compiler, but it's ugly.
> I wouldn't be surprised if there was a portability issue with free
> format .F90 files, so I figured I'd check.
> 2. Is there a reason PETSC_SCALAR is defined in finclude/petscsysdef.h,
> but PETSC_REAL is not? Using PETSC_USE_FORTRAN_MODULES and "use petsc",
> I get implicit declaration errors when using PETSC_REAL (but
> PETSC_SCALAR is defined as expected).
> The below patch fixes this issue, assuming I'm not missing something...
> diff -r b702b1062e33 include/finclude/petscsysdef.h
> --- a/include/finclude/petscsysdef.h Mon May 09 15:26:40 2011 -0600
> +++ b/include/finclude/petscsysdef.h Tue May 10 10:41:35 2011 -0600
> @@ -115,7 +115,14 @@
> #define PETSC_SCALAR PETSC_LONG_DOUBLE
> #elif defined(PETSC_USE_REAL_DOUBLE)
> #define PETSC_SCALAR PETSC_DOUBLE
> -#endif
> +#endif
> +#endif
> +#if defined(PETSC_USE_REAL_SINGLE)
> +#define PETSC_REAL PETSC_FLOAT
> +#elif defined(PETSC_USE_REAL_LONG_DOUBLE)
> +#define PETSC_REAL PETSC_LONG_DOUBLE
> +#else
> +#define PETSC_REAL PETSC_DOUBLE
> #endif
> ! Macro for templating between real and complex
> Ethan Coon
> Post-Doctoral Researcher
> Applied Mathematics - T-5
> Los Alamos National Laboratory
> 505-665-8289
> http://www.ldeo.columbia.edu/~ecoon/
