[petsc-dev] PetscBag not a PetscObject?
Ethan Coon ecoon at lanl.gov
Tue May 10 12:28:10 CDT 2011
Attached is a patch to hack in an prefix for use with PetscBag.  Also
fixed the PetscBag examples to work.
Note that the fortran example doesn't compile unless the PETSC_REAL
patch I sent in the previous example is included, as PETSC_REAL doesn't
seem to exist in either finclude/petscsysdef.h or petsc.mod.
Ethan
On Fri, 2011-04-08 at 21:55 -0500, Barry Smith wrote:
> At this time I vote that you add the PetscBagSetOptionsPrefix() directly for Bags and do not turn the Bag into a real PetscObject.
>    Barry
> On Apr 8, 2011, at 12:29 PM, Ethan Coon wrote:
> > I'm using a couple of bags in an application, and that application is in
> > turn being used in a domain-decomposition algorithm with multiple
> > domains (each an instance of the application).  So I'd like to set the
> > options prefix of the bag, so that each application instance has its own
> > prefix and can be used with the same options "database."  Currently
> > PetscBag passes PETSC_NULL for the prefix.
> > To fix this, it looks like the best option would be to have a
> > PetscBagSetOptionsPrefix() in the same mold as everything else.  I added
> > this, and then found out that PetscBag isn't a PetscObject, in the sense
> > that it has no header or CLASS_ID (so PetscObjectSetOptionsPrefix()
> > doesn't work on a bag).
> > Is this the best way forward, to make PetscBag a PetscObject, with
> > CLASS_ID, etc?  And if so, is there a good example of this that I should
> > follow to do so?
> > Thanks,
> > Ethan
> > Ethan Coon
> > Post-Doctoral Researcher
> > Applied Mathematics - T-5
> > Los Alamos National Laboratory
> > 505-665-8289
> > http://www.ldeo.columbia.edu/~ecoon/
Ethan Coon
505-665-8289
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110510/3e68f0b6/attachment.bin>
Type: text/x-patch
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110510/3e68f0b6/attachment-0001.bin>
