[petsc-dev] preparing for a PETSc release
    Jed Brown
    jed at 59A2.org
    Mon May  9 16:03:58 CDT 2011
On Mon, May 9, 2011 at 22:53, Blaise Bourdin <bourdin at lsu.edu> wrote:
> How feasible would it be to mark all non-namespace names as deprecated
> until the next release but offer preprocessor macros in the meantime? This
> would buy everybody some time.
Is the problem that you want to delay running "sed" on your project, or that
you want to support older versions of PETSc for a little longer? If the
latter, what about a header that went the other way (update your code now,
include the header when building against petsc-3.1)?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110509/1a495b06/attachment.html>
