[petsc-dev] About PCFieldSplitGetSubKSP
Barry Smith
bsmith at mcs.anl.gov
Sat May 7 22:34:39 CDT 2011
On May 7, 2011, at 9:12 PM, Ryan Yan wrote:
> Dear All,
> I have a question about the function call PCFieldSplitSetFields() in the developer version.
> I would like to name of each field separately, and using some
> rule based on the count of i.
> For instance, I would try:
> for (i = 0; i < m/3; i++) {
> ierr = PCFieldSplitSetFields(pc,"0",xxx,xxx);
> ierr = PCFieldSplitSetFields(pc,"1",xxx,xxx);
> When m=3 this is fine, since there is only one pass, namely, '0' and '1' is fine
> When m=6, I want 4 fields. But how can I set up the name as '3' and '4' after the first pass in the loop.
> I think the question is how to fill up an char[] dynamically as a integer array?
The standard C function scanf().
Barry
> This might be a naive question, but I did not come up any way of doing it.
> Many thanks,
> Yan
