[petsc-dev] [petsc-maint #68731] Installation problem with petsc4py
Barry Smith
bsmith at mcs.anl.gov
Thu Mar 31 11:40:12 CDT 2011
On Mar 30, 2011, at 2:49 PM, David Maxwell wrote:
> Barry, Andy:
> I suppose you can avoid both these gotchas by involving the end user in the choice rather than making it arbitrarily. For example, in reconfigure:
> * Don't hardwire the python executable, but
> * Check that the python executable running the script is the original one (compare sys.executable with a stored value).
> If there is a mismatch, print a meaningful error message telling the user to either run the script explicitly with the original python, or to set a command line flag indicating the current python is to be used (and is then a part of the reconfiguration).
Good idea. Satish, unless you can find a problem with this suggestion could you please make this change.
> Speaking of meaningful error messages, the message from petsc4py.Configure.configureLibrary:
> realpath of /usr/lib/libpython.dylib (/System/Library/Frameworks/Python.framework/Versions/2.6/Python) does not point to Python library path (/Library/Frameworks/Python.framework/Versions/6.1/Python) for current Python;
> Are you not using the Apple python?
Fixed.
Barry
> is misleading since the current python library path is not obliged to be /usr/lib/libpython's realpath, but can also be one of a handful of hardcoded macports pythons as well.
> -David
>> We've had endless discussions about this. If we don't hardwire it and someone runs the reconfigure... after a path change then they get something different and get very confused. If we do hardware it then it cannot easily use a different python the way a user might think it would. We've had people screwed on both sides of this (we didn't used to hardware it).
>> If you have a solution distinct from those two flawed schemes we'd love to try it.
>> Barry
>>> Cheers,
>>> Andy
>>> On Mar 29, 2011, at 11:09 PM, Matthew Knepley wrote:
>>>> On Tue, Mar 29, 2011 at 9:18 PM, Andy Aschwanden <andy.aschwanden at arsc.edu> wrote:
>>>> Dear PETSc developers
>>>> I'm trying to install petsc-3.1-p4 with --download-petsc4py on my OSX 10.6, and get the following error:
>>>> TESTING: configureLibrary from PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:43) *******************************************************************************
>>>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>>>> Detailed configure.log is attached.
>>>> The answer to the above question is: I'm *NOT* using the Apple python, instead I have python26 installed via MacPorts. There are, however, various python installations on my system, including an EPD 6.1 in /Library/Frameworks/Python.framework/Versions/6.1/Python.
>>>> I will look at the log, but this install is no longer the easiest one. If you just install
>>>> PETSc, and then use
>>>> pip install petsc4py
>>>> when you have PETSC_DIR and PETSC_ARCH defined, it should work.
>>>> Thanks,
>>>> Matt
>>>> I did
>>>> $ python_select python26
>>>> to select the MacPorts python distribution I want to use with petsc4py, and indeed
>>>> $ which python
>>>> /opt/local/bin/python
>>>> points to the right place. I don't know why petsc picks up the wrong python. Is there a way to tell petsc which python version it should use for petsc4py.
>>>> Thanks,
>>>> Andy
>>>> CC: David Maxwell
>>>> Dr. Andy Aschwanden
>>>> ARSC Postdoctoral Fellow
>>>> Geophysical Institute
>>>> 903 Koyukuk Drive
>>>> Fairbanks AK 99775
>>>> USA
>>>> email andy.aschwanden at arsc.edu
>>>> phone +1 (907) 474-7199
>>>> fax +1 (907) 474-7290
>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>> -- Norbert Wiener
>>> Dr. Andy Aschwanden
>>> 903 Koyukuk Drive
>>> Fairbanks AK 99775
>>> USA
