[petsc-dev] Preconditioner for Schur complement (pcfieldsplit)
Thomas Witkowski
thomas.witkowski at tu-dresden.de
Tue Mar 29 07:29:04 CDT 2011
Jed Brown wrote:
> On Tue, Mar 29, 2011 at 13:12, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
> PCFieldsplitSchurPrecondition seems to do what I want. But how to
> create the matrix for the preconditioner? I'm a little bit
> confused about it because the matrix/operator S acts on an index
> range that does not start from 0 and is not continuous, because
> each rank owns only some parts of the interior domain boundaries.
> We do not currently have a way to set attributes on a "submatrix" that
> you will extract in the future. You can implement MatGetSubMatrix to
> return your special matrix for that block when called with that pair
> of ISs. Or you can use MatNest for the preconditioning matrix, it is
> frequently a good storage format when doing fieldsplit and you can use
> it unintrusively.
MatNest sounds good. Is there any example which makes use of it?
Thomas
