[petsc-dev] generatefortranstubs.py cannot run concurrently
Jed Brown
jed at 59A2.org
Sat Mar 26 02:23:45 CDT 2011
Can temporary files be put in a private directory so that multiple
reconfigures can be run simultaneously? I think the rest of configure works.
UNABLE to EXECUTE BINARIES for ./configure
[Errno 2] No such file or directory:
'/home/jed/petsc/src/sys/viewer/interface/f90module.f90'
File "/home/jed/petsc/config/configure.py", line 272, in petsc_configure
framework.configure(out = sys.stdout)
File "/home/jed/petsc/config/BuildSystem/config/framework.py", line 922,
in configure
child.configure()
File "/home/jed/petsc/config/PETSc/packages/sowing.py", line 123, in
configure
self.buildFortranStubs()
File "/home/jed/petsc/config/PETSc/packages/sowing.py", line 83, in
buildFortranStubs
generatefortranstubs.main(self.petscdir.dir, self.bfort,
self.petscdir.dir)
File "/home/jed/petsc/bin/maint/generatefortranstubs.py", line 196, in
main
os.path.walk(dir, processDir, [petscdir, bfort])
File "/usr/lib/python2.7/posixpath.py", line 237, in walk
walk(name, func, arg)
File "/usr/lib/python2.7/posixpath.py", line 229, in walk
func(arg, top, names)
File "/home/jed/petsc/bin/maint/generatefortranstubs.py", line 161, in
processDir
FixDir(petscdir,outdir)
File "/home/jed/petsc/bin/maint/generatefortranstubs.py", line 123, in
FixDir
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110326/3f066678/attachment.html>
