[petsc-dev] MatNullSpaceDestroy
Wed Mar 23 19:16:45 CDT 2011
On Wed, Mar 23, 2011 at 7:12 PM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 23 March 2011 20:09, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Mar 23, 2011, at 5:58 PM, Lisandro Dalcin wrote:
> >> Are you going to rename MatNullSpaceDestroy -> MatNullSpaceDestroy_
> >> and add the backward compatibility #define? Changeset 1a6f5fc1c27b
> >> broke petsc4py...
> >   No, it was changed to the &object paradigm.
> >   Basically what is happening now is that commonly used destroys are
> changed with the _ paradigm
> >   Uncommonly used destroy are fixed to use the &object paradigm.
> Understood... I'm going to fix petsc4py...
I already fixed MatNullSpaceDestroy().
  Matt
> >   Don't like the fact that there are two paradigms well I could change
> everything to & immediately :-(
> >   Barry
> >   Eventually I want to switch to the &object paradigm for everything but
> I decided to be nice to Matt and leave the common ones with the same API so
> users don't have to change their codes much.
> I still feel we should use a different approach for backward
> compatibility... Perhaps adding a petsccompat.h header file (or even
> compat/petscXXX.h headers) with backward compatibility macro defs and
> even STATIC_INLINE routines, in order to help people switch
> incrementally.
> My concern is that if you do not make pressure on users RIGHT NOW to
> forcibly notice there is a new API's, most of them are going simply
> ignore the changes, pretend they old API is fine to use, and finally
> cry in the next release petsc-3.3 because their code is finally
> broken.
> Please note that this is the approach I use for petsc4py, right now
> petsc4py-dev can build back to petsc-3.0.0. Of course, a potential
> petsccompat.h should have a reverse direction of compatibility for
> what I have in petsc4py
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110323/3f3e5c67/attachment.html>
