[petsc-dev] MatNullSpaceDestroy
Barry Smith
bsmith at mcs.anl.gov
Wed Mar 23 18:09:29 CDT 2011
On Mar 23, 2011, at 5:58 PM, Lisandro Dalcin wrote:
> Are you going to rename MatNullSpaceDestroy -> MatNullSpaceDestroy_
> and add the backward compatibility #define? Changeset 1a6f5fc1c27b
> broke petsc4py...
No, it was changed to the &object paradigm.
Basically what is happening now is that commonly used destroys are changed with the _ paradigm
Uncommonly used destroy are fixed to use the &object paradigm.
Don't like the fact that there are two paradigms well I could change everything to & immediately :-(
Barry
Eventually I want to switch to the &object paradigm for everything but I decided to be nice to Matt and leave the common ones with the same API so users don't have to change their codes much.
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
