[petsc-dev] hg diff question
Wed Mar 23 16:52:40 CDT 2011
On Wed, Mar 23, 2011 at 4:47 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 23 Mar 2011, Matthew Knepley wrote:
> > On Wed, Mar 23, 2011 at 3:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >  hg diff src/makefile
> > >   How come there isn't an option to have it show the most recent set of
> > > changes? It seems I have to hunt down some "revision numbers" and type
> them
> > > in the request to get any useful information? How about something like
> > >  hg diff --last src/makefile
> > The closest I can find is
> >   hg diff -r-2 src/makefile
> > which diffs against the first revision before tip. However, if you pull a
> > bunch of revisions, there
> > is no guarantee that is right. You can generate this diff before the pull
> > using 'hg incoming', but
> > I can't yet find a command to give me the last thing pulled down.
> hg diff by default does diff with working dir. What you want is:
> hg diff -c tip
> or
> hg diff -c -2
> The relative-rev numbering is based on full changeset numbering from
> tip - and not selective-file-changeset nubmering - which is what Barry
> wants.. I don't know if that exists..
I will point out that this would be easy to write as an extension. We use
a 'bsmithdiff' diff that first calls 'log' to get the sequence of changesets
for this file, and then counts backwards.
   Matt
> Satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110323/71fc16b5/attachment.html>
