[petsc-dev] Bug in petsc-dev?
Jed Brown jed at 59A2.org
Wed Mar 23 07:07:36 CDT 2011
On Wed, Mar 23, 2011 at 12:50, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> I found the problem: on the parallel system I make use of the environment
> variable $DISPLAY is set only on the first node of the parallel job. On all
> other nodes this variable is set to an empty string. This brings trouble in
> the function PetscSetDisplay():
Thank you for tracking this down. I made this function always broadcast so
that every process is assured the same value for PetscDisplay. Could you
pull from Hg and confirm that this works.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110323/104a969a/attachment.html>
