[petsc-dev] Should pARMS converge in parallel?
Jose E. Roman
jroman at dsic.upv.es
Tue Mar 22 11:05:58 CDT 2011
El 18/03/2011, a las 19:29, Jed Brown escribió:
> On Fri, Mar 18, 2011 at 19:14, Jose E. Roman <jroman at dsic.upv.es> wrote:
> I am attaching a patch that sets default values that should work irrespective of the number of processors, even without flexible solvers.
> Jed, can you commit the changes?
> Thanks, pushed.
Based on feedback received from one of the pARMS developers, I am attaching a patch that modifies some default values.
Jed, can you push again?
Jose
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110322/062bcbb2/attachment.obj>
