[petsc-dev] [petsc-maint #67637] Re: [petsc-users] Scalability of AO ?
Matthew Knepley
petsc-maint at mcs.anl.gov
Mon Mar 21 18:06:16 CDT 2011
On Mon, Mar 21, 2011 at 5:36 PM, Satish Balay <petsc-maint at mcs.anl.gov>wrote:
> Hm - why did I think Dmitry added libcharacteristic.a? I can't
> figureout who added this library - so
> Matt, Barry - Should it go into libpetscdm.a?
1) I added it a few years ago
2) It holds the method of characteristics
3) It should go into TS
Matt
> Satish
> On Mon, 21 Mar 2011, Satish Balay wrote:
> > Dmitry,
> > We can't have a library disappear between real/complex builds. Is
> > there a different library that can take in these symbols?
> > Note: not all petsc objects get a library of their own. For eg: IS
> > goes into libpetscvec etc..
> > Satish
> > On Mon, 21 Mar 2011, Jose E. Roman wrote:
> > > src/characteristic/makefile has #requiresscalar real, so
> libcharacteristic.a is not created with-scalar-type=complex.
> > > 'make test' fails in this case.
> > > Also, with cmake builds:
> > > Scanning dependencies of target petsccharacteristic
> > > make[2]: *** No rule to make target
> `CMakeFiles/petsccharacteristic.dir/build'. Stop.
> > > make[1]: *** [CMakeFiles/petsccharacteristic.dir/all] Error 2
> > > make[1]: *** Waiting for unfinished jobs....
> > > Jose
> > > El 21/03/2011, a las 22:20, Satish Balay escribió:
> > > > added
> > > > satish
> > > > On Mon, 21 Mar 2011, Barry Smith wrote:
> > > >> Maybe we just need to force Satish to have a nightly build that
> checks the several library tests.
> > > >> Barry
> > > >> On Mar 21, 2011, at 4:10 PM, Jed Brown wrote:
> > > >>> On Mon, Mar 21, 2011 at 22:07, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > >>> Why do you care if there are dependencies? Admittedly that may make
> PETSc harder to develop and maintain
> > > >>> Exactly.
> > > >>> but from the user point of view what is wrong with just having one
> big-assed blob?
> > > >>> It doesn't matter for users.
> > > >>> (But a circular dependency would make executables grow so its
> existence might matter to someone using only Mat+Vec in an extremely
> low-memory environment.)
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110321/06d0f5dd/attachment.html>
