[petsc-dev] [petsc-maint #67637] Re: [petsc-users] Scalability of AO ?
Satish Balay petsc-maint at mcs.anl.gov
Mon Mar 21 17:28:18 CDT 2011
Dmitry,
We can't have a library disappear between real/complex builds. Is
there a different library that can take in these symbols?
Note: not all petsc objects get a library of their own. For eg: IS
goes into libpetscvec etc..
Satish
On Mon, 21 Mar 2011, Jose E. Roman wrote:
> src/characteristic/makefile has #requiresscalar real, so libcharacteristic.a is not created with-scalar-type=complex.
> 'make test' fails in this case.
> Also, with cmake builds:
> Scanning dependencies of target petsccharacteristic
> make[2]: *** No rule to make target `CMakeFiles/petsccharacteristic.dir/build'.  Stop.
> make[1]: *** [CMakeFiles/petsccharacteristic.dir/all] Error 2
> make[1]: *** Waiting for unfinished jobs....
> Jose
> El 21/03/2011, a las 22:20, Satish Balay escribió:
> > added
> > satish
> > On Mon, 21 Mar 2011, Barry Smith wrote:
> >>   Maybe we just need to force Satish to have a nightly build that checks the several library tests.
> >>   Barry
> >> On Mar 21, 2011, at 4:10 PM, Jed Brown wrote:
> >>> On Mon, Mar 21, 2011 at 22:07, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>> Why do you care if there are dependencies? Admittedly that may make PETSc harder to develop and maintain
> >>> Exactly.
> >>> but from the user point of view what is wrong with just having one big-assed blob?
> >>> It doesn't matter for users.
> >>> (But a circular dependency would make executables grow so its existence might matter to someone using only Mat+Vec in an extremely low-memory environment.)
