[petsc-dev] Using PCFieldSplitSetIS
Barry Smith
bsmith at mcs.anl.gov
Fri Mar 18 10:01:13 CDT 2011
On Mar 18, 2011, at 6:23 AM, Thomas Witkowski wrote:
> Barry Smith wrote:
>> Did you get a chance to run as I requested with "Please run with -ksp_view and send the output."
> Yes, the problem with the second iteration occurs only when I make use of bcgs for the outer iteration
OK, then everything is FINE. BCGS applies the operator and preconditioner twice per iteration, so this is the expected behavior.
Barry
> (which is set in my code as the standard solver). When using richardson or gmres, I get the expected output. Here is the output for -ksp_type bcgs and -ksp_view
> Residual norms for fieldsplit_boundary_ solve.
> 0 KSP Residual norm 1.238748554482e+02
> 1 KSP Residual norm 1.712708691574e+01
> 2 KSP Residual norm 5.537715643639e+00
> 3 KSP Residual norm 2.767431394864e+00
> 4 KSP Residual norm 2.308410861046e+00
> 5 KSP Residual norm 1.225474327957e+00
> 6 KSP Residual norm 4.705888493777e-01
> 7 KSP Residual norm 4.476449896581e-01
> 8 KSP Residual norm 1.859190943730e-01
> 9 KSP Residual norm 9.038347953900e-02
> 10 KSP Residual norm 7.545891428899e-02
> 11 KSP Residual norm 4.046165237615e-02
> 12 KSP Residual norm 1.499755811468e-02
> 13 KSP Residual norm 1.100288579779e-02
> 14 KSP Residual norm 4.530437449505e-03
> 15 KSP Residual norm 2.511112676997e-03
> 16 KSP Residual norm 1.425956836799e-03
> 17 KSP Residual norm 1.008189124008e-03
> 18 KSP Residual norm 4.759971096889e-04
> 19 KSP Residual norm 2.418445744584e-04
> 20 KSP Residual norm 1.345530122184e-04
> 21 KSP Residual norm 6.618130426631e-05
> 22 KSP Residual norm 3.502075214549e-05
> 23 KSP Residual norm 2.093145547362e-05
> 24 KSP Residual norm 1.426936785120e-05
> 25 KSP Residual norm 6.716866486925e-06
> 26 KSP Residual norm 2.938650130672e-06
> 27 KSP Residual norm 1.194333200607e-06
> 28 KSP Residual norm 8.117544753927e-07
> 29 KSP Residual norm 4.436526804864e-07
> 30 KSP Residual norm 2.619889310859e-07
> 31 KSP Residual norm 2.608365614137e-07
> 32 KSP Residual norm 2.502840136682e-07
> 33 KSP Residual norm 2.108068726014e-07
> 34 KSP Residual norm 1.190606661068e-07
> 35 KSP Residual norm 8.587022449664e-08
> 36 KSP Residual norm 2.657505256794e-08
> 37 KSP Residual norm 1.091795047578e-08
> 38 KSP Residual norm 5.622627482150e-09
> Linear solve converged due to CONVERGED_ATOL iterations 38
> 0 KSP preconditioned resid norm 1.039480141214e+02 true resid norm 2.318397033201e+03 ||r(i)||/||b|| 1.000000000000e+00
> 0 KSP Residual norm 1.238748554488e+02
> 1 KSP Residual norm 1.712708691920e+01
> 2 KSP Residual norm 5.537715644318e+00
> 3 KSP Residual norm 2.767431394929e+00
> 4 KSP Residual norm 2.308410861005e+00
> 5 KSP Residual norm 1.225474328165e+00
> 6 KSP Residual norm 4.705888492572e-01
> 7 KSP Residual norm 4.476449894826e-01
> 8 KSP Residual norm 1.859190943717e-01
> 9 KSP Residual norm 9.038347954447e-02
> 10 KSP Residual norm 7.545891428241e-02
> 11 KSP Residual norm 4.046165236351e-02
> 12 KSP Residual norm 1.499755811079e-02
> 13 KSP Residual norm 1.100288580023e-02
> 14 KSP Residual norm 4.530437448754e-03
> 15 KSP Residual norm 2.511112675547e-03
> 16 KSP Residual norm 1.425956832972e-03
> 17 KSP Residual norm 1.008189121211e-03
> 18 KSP Residual norm 4.759971083063e-04
> 19 KSP Residual norm 2.418445729000e-04
> 20 KSP Residual norm 1.345530095639e-04
> 21 KSP Residual norm 6.618130177611e-05
> 22 KSP Residual norm 3.502074795980e-05
> 23 KSP Residual norm 2.093145116748e-05
> 24 KSP Residual norm 1.426936277614e-05
> 25 KSP Residual norm 6.716863232176e-06
> 26 KSP Residual norm 2.938647588875e-06
> 27 KSP Residual norm 1.194330143586e-06
> 28 KSP Residual norm 8.117422448346e-07
> 29 KSP Residual norm 4.436425441849e-07
> 30 KSP Residual norm 2.619889078643e-07
> 31 KSP Residual norm 2.608368186135e-07
> 32 KSP Residual norm 2.502849238080e-07
> 33 KSP Residual norm 2.108123763958e-07
> 34 KSP Residual norm 1.190912989234e-07
> 35 KSP Residual norm 8.589705060827e-08
> 36 KSP Residual norm 2.657654667253e-08
> 37 KSP Residual norm 1.091743530704e-08
> 38 KSP Residual norm 5.623018769513e-09
> 0 KSP Residual norm 5.628142396422e-09
> Linear solve converged due to CONVERGED_ATOL iterations 0
> 1 KSP preconditioned resid norm 2.834168769772e-08 true resid norm 5.737810813629e-09 ||r(i)||/||b|| 2.474904311669e-12
> 0 KSP Residual norm 5.626350752150e-09
> 2 KSP preconditioned resid norm 2.834287716574e-08 true resid norm 1.921317696012e-06 ||r(i)||/||b|| 8.287267747921e-10
> 0 KSP Residual norm 6.360593934279e-07
> 1 KSP Residual norm 6.207657513778e-07
> 2 KSP Residual norm 4.595521952584e-07
> 3 KSP Residual norm 2.353791066544e-07
> 4 KSP Residual norm 1.659055771510e-07
> 5 KSP Residual norm 1.057381480368e-07
> 6 KSP Residual norm 2.733159212163e-08
> 7 KSP Residual norm 1.685966550943e-08
> 8 KSP Residual norm 5.250226264235e-09
> Linear solve converged due to CONVERGED_ATOL iterations 8
> 0 KSP Residual norm 5.314638497757e-10
> 3 KSP preconditioned resid norm 2.418607617684e-09 true resid norm 1.943729846844e-06 ||r(i)||/||b|| 8.383938639538e-10
> KSP Object:
> type: bcgs
> maximum iterations=10000, initial guess is zero
> tolerances: relative=0, absolute=1e-08, divergence=10000
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object:
> type: fieldsplit
> FieldSplit with Schur preconditioner, blocksize = -1, factorization FULL
> Split info:
> Split number 0 Defined by IS
> Split number 1 Defined by IS
> KSP solver for A00 block
> KSP Object: (fieldsplit_interior_) type: preonly
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> PC Object: (fieldsplit_interior_) type: bjacobi
> block Jacobi: number of blocks = 2
> Local solve is same for all blocks, in the following KSP and PC objects:
> KSP Object: (fieldsplit_interior_sub_) type: preonly
> PC Object: (fieldsplit_interior_sub_) type: lu
> LU: out-of-place factorization
> tolerance for zero pivot 1e-12
> matrix ordering: nd
> factor fill ratio given 0, needed 0
> Factored matrix follows:
> Matrix Object: type: seqaij
> rows=12336, cols=12336
> package used to perform factorization: umfpack
> total: nonzeros=0, allocated nonzeros=0
> total number of mallocs used during MatSetValues calls =0
> not using I-node routines
> UMFPACK run parameters:
> Control[UMFPACK_PRL]: 1
> Control[UMFPACK_STRATEGY]: 0
> Control[UMFPACK_DENSE_COL]: 0.2
> Control[UMFPACK_DENSE_ROW]: 0.2
> Control[UMFPACK_AMD_DENSE]: 10
> Control[UMFPACK_BLOCK_SIZE]: 32
> Control[UMFPACK_2BY2_TOLERANCE]: 0.01
> Control[UMFPACK_FIXQ]: 0
> Control[UMFPACK_AGGRESSIVE]: 1
> Control[UMFPACK_PIVOT_TOLERANCE]: 0.1
> Control[UMFPACK_SYM_PIVOT_TOLERANCE]: 0.001
> Control[UMFPACK_SCALE]: 1
> Control[UMFPACK_ALLOC_INIT]: 0.7
> Control[UMFPACK_DROPTOL]: 0
> Control[UMFPACK_IRSTEP]: 0
> UMFPACK default matrix ordering is used (not the PETSc matrix ordering)
> linear system matrix = precond matrix:
> total: nonzeros=173608, allocated nonzeros=173608
> Matrix Object: type: mpiaij
> rows=24672, cols=24672
> total: nonzeros=347216, allocated nonzeros=347216
> not using I-node (on process 0) routines
> KSP solver for S = A11 - A10 inv(A00) A01
> KSP Object: (fieldsplit_boundary_) type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> tolerances: relative=1e-50, absolute=1e-08, divergence=10000
> PC Object: (fieldsplit_boundary_) type: bjacobi
> KSP Object: (fieldsplit_boundary_sub_) type: preonly
> PC Object: (fieldsplit_boundary_sub_) type: ilu
> ILU: out-of-place factorization
> 0 levels of fill
> using diagonal shift to prevent zero pivot
> matrix ordering: natural
> factor fill ratio given 1, needed 1
> rows=0, cols=0
> package used to perform factorization: petsc
> rows=0, cols=0
> linear system matrix followed by preconditioner matrix:
> Matrix Object: type: schurcomplement
> rows=291, cols=291
> Schur complement A11 - A10 inv(A00) A01
> A11
> rows=291, cols=291
> total: nonzeros=1831, allocated nonzeros=1831
> A10
> rows=291, cols=24672
> total: nonzeros=2568, allocated nonzeros=2568
> KSP of A00
> matrix ordering: nd
> A01
> rows=24672, cols=291
> using I-node (on process 0) routines: found 2468 nodes, limit used is 5
> rows=291, cols=291
> rows=24963, cols=24963
> total: nonzeros=354183, allocated nonzeros=356014
> Thomas
>> We are eager to determine the problem.
>> Barry
>> On Mar 16, 2011, at 11:03 AM, Barry Smith wrote:
>>> On Mar 16, 2011, at 8:57 AM, Thomas Witkowski wrote:
>>> -pc_fieldsplit_type schur -fieldsplit_interior_ksp_type preonly -fieldsplit_interior_pc_type bjacobi -fieldsplit_interior_sub_pc_type lu -fieldsplit_boundary_ksp_monitor -ksp_monitor_true_residual
>>>> 0 KSP Residual norm 1.790059331071e-04
>>>> 18 KSP Residual norm 1.593454221996e-09
>>>> 0 KSP preconditioned resid norm 5.745043818120e-01 true resid norm 1.584249437360e-01 ||r(i)||/||b|| 1.000000000000e+00
>>> This is the norms on the outer iteration variables
>>>> 0 KSP Residual norm 1.790059331000e-04
>>> This is the norms on the Schur complement iteration
>>>> 18 KSP Residual norm 1.593449602302e-09
>>> It is unclear to me why it starts up another solve here, starting basically where it left off. I think it should just kick out to print the norm of the residual of the outer iteration.
>>>> 0 KSP Residual norm 1.593449603155e-09
>>>> 18 KSP Residual norm 1.335744434252e-14
>>>> 1 KSP preconditioned resid norm 2.608069232839e-13 true resid norm 1.449869994655e-13 ||r(i)||/||b|| 9.151778504469e-13
>>> Are you running with petsc-dev?
>>> When I run tutorials/multiphysics/mp.c with the options ./mp -couple -snes_monitor_short -pc_type fieldsplit -ksp_monitor -pc_fieldsplit_type schur -fieldsplit_ksp_monitor -fieldsplit_1_ksp_type fgmres -fieldsplit_0_ksp_type gmres -snes_view I do not see the "double" iteration business.
>>> Barry
>>>> So, are there now two or one outer iterations?
>>>> Thomas
>>>> Matthew Knepley wrote:
>>>>> On Wed, Mar 16, 2011 at 8:27 AM, Thomas Witkowski <thomas.witkowski at tu-dresden.de <mailto:thomas.witkowski at tu-dresden.de>> wrote:
>>>>> Jed Brown wrote:
>>>>> On Wed, Mar 16, 2011 at 07:37, Thomas Witkowski
>>>>> <mailto:thomas.witkowski at tu-dresden.de>>> wrote:
>>>>> Thanks for explanations! It works fine in my code. But I
>>>>> have two
>>>>> questions about it, maybe you can help me with them:
>>>>> - To the first, is the LU factorization on block A_00 done
>>>>> only once?
>>>>> Yes, one way to confirm this is to run with -log_summary and
>>>>> check MatLUFactor{Sym,Num}.
>>>>> - I have run the code with -fieldsplit_1_ksp_monitor to get
>>>>> some
>>>>> more information about the internal solves. I expected to get
>>>>> information about one iterative solver (for solving the Schur
>>>>> complement system), but I got three, all of them need around 20
>>>>> iterations for my example. Could you explain to me what is
>>>>> actually solved there?
>>>>> I'm going to guess that you still have an outer KSP that (in
>>>>> the global norm, rather than the partitioned norm used inside
>>>>> of splits) has a tighter tolerance, therefore it takes a few
>>>>> outer iterations. If you use loose inner tolerances then the
>>>>> preconditioner becomes nonlinear and you'll need to use FGMRES
>>>>> for the outer. When in doubt, run with -ksp_view and show us
>>>>> the results if you don't understand. Additionally, monitoring
>>>>> inner solves separately can be useful, e.g.
>>>>> -fieldsplit_0_ksp_converged_reason -fieldsplit_1_ksp_monitor
>>>>> -ksp_monitor_true_residual.
>>>>> Okay, I run my code with the options "-pc_fieldsplit_type schur
>>>>> -fieldsplit_interior_ksp_converged_reason". The splits are named
>>>>> "interior" and "boundary". The ksp output is as follows:
>>>>> Linear solve converged due to CONVERGED_ITS iterations 1
>>>>> 1 KSP Residual norm 1.237356212928e-04
>>>>> 2 KSP Residual norm 7.952220245101e-05
>>>>> 3 KSP Residual norm 3.502858665398e-05
>>>>> 4 KSP Residual norm 1.601085190129e-05
>>>>> 5 KSP Residual norm 8.491161243057e-06
>>>>> 6 KSP Residual norm 4.778227395989e-06
>>>>> 7 KSP Residual norm 2.571919352633e-06
>>>>> 8 KSP Residual norm 1.353979940120e-06
>>>>> 9 KSP Residual norm 7.408377337496e-07
>>>>> 10 KSP Residual norm 3.810694345834e-07
>>>>> 11 KSP Residual norm 1.955889542056e-07
>>>>> 12 KSP Residual norm 9.938906113920e-08
>>>>> 13 KSP Residual norm 4.893445675773e-08
>>>>> 14 KSP Residual norm 2.395128458062e-08
>>>>> 15 KSP Residual norm 1.2464425896 <tel:1.2464425896>57e-08
>>>>> 16 KSP Residual norm 6.316454504022e-09
>>>>> 17 KSP Residual norm 3.088668836241e-09
>>>>> [0] Petsc-Iteration 0: 0.574504
>>>>> 1 KSP Residual norm 1.237356237744e-04
>>>>> 2 KSP Residual norm 7.952220078415e-05
>>>>> 3 KSP Residual norm 3.502859285561e-05
>>>>> 4 KSP Residual norm 1.601086485810e-05
>>>>> 5 KSP Residual norm 8.491169384185e-06
>>>>> 6 KSP Residual norm 4.778229157872e-06
>>>>> 7 KSP Residual norm 2.571917112191e-06
>>>>> 8 KSP Residual norm 1.353977280183e-06
>>>>> 9 KSP Residual norm 7.408352317360e-07
>>>>> 10 KSP Residual norm 3.810710583336e-07
>>>>> 11 KSP Residual norm 1.955898169394e-07
>>>>> 12 KSP Residual norm 9.938892788465e-08
>>>>> 13 KSP Residual norm 4.893428546840e-08
>>>>> 14 KSP Residual norm 2.395120857135e-08
>>>>> 15 KSP Residual norm 1.2464367927 <tel:1.2464367927>84e-08
>>>>> 16 KSP Residual norm 6.316409779118e-09
>>>>> 17 KSP Residual norm 3.088649355374e-09
>>>>> 1 KSP Residual norm 1.011857676662e-09
>>>>> 2 KSP Residual norm 5.660892669788e-10
>>>>> 3 KSP Residual norm 3.046799343903e-10
>>>>> 4 KSP Residual norm 1.6004713993 <tel:1.6004713993>29e-10
>>>>> 5 KSP Residual norm 8.083216601016e-11
>>>>> 6 KSP Residual norm 4.308671648345e-11
>>>>> 7 KSP Residual norm 2.381959817139e-11
>>>>> 8 KSP Residual norm 1.264839790114e-11
>>>>> 9 KSP Residual norm 6.435098853282e-12
>>>>> 10 KSP Residual norm 3.184769579797e-12
>>>>> 11 KSP Residual norm 1.5022019430 <tel:1.5022019430>16e-12
>>>>> 12 KSP Residual norm 7.099486208425e-13
>>>>> 13 KSP Residual norm 3.443222176388e-13
>>>>> 14 KSP Residual norm 1.6478434989 <tel:1.6478434989>12e-13
>>>>> 15 KSP Residual norm 8.208508173926e-14
>>>>> 16 KSP Residual norm 4.376604355287e-14
>>>>> 17 KSP Residual norm 2.596069152755e-14
>>>>> I have no idea how to interpret this output! Could you help me
>>>>> with it?
>>>>> Get rid of -fieldsplit_interior_ksp_converged_reason. It is confusing things. Then you will see
>>>>> the outer iteration and the inner boundary iteration which is indented.
>>>>> Matt
>>>>> Thomas
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
