[petsc-dev] Using PCFieldSplitSetIS
Thomas Witkowski
thomas.witkowski at tu-dresden.de
Fri Mar 18 06:16:14 CDT 2011
Jed, thanks for clarification. I think that I now understand whats going
when using the fieldsplit preconditioner.
Thomas
Jed Brown wrote:
> On Wed, Mar 16, 2011 at 14:27, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> <mailto:thomas.witkowski at tu-dresden.de>> wrote:
> I'm going to guess that you still have an outer KSP that (in
> the global norm, rather than the partitioned norm used inside
> of splits) has a tighter tolerance, therefore it takes a few
> outer iterations. If you use loose inner tolerances then the
> preconditioner becomes nonlinear and you'll need to use FGMRES
> for the outer. When in doubt, run with -ksp_view and show us
> the results if you don't understand. Additionally, monitoring
> inner solves separately can be useful, e.g.
> -fieldsplit_0_ksp_converged_reason -fieldsplit_1_ksp_monitor
> -ksp_monitor_true_residual.
> Okay, I run my code with the options "-pc_fieldsplit_type schur
> -fieldsplit_interior_ksp_type preonly -fieldsplit_interior_pc_type
> bjacobi -fieldsplit_interior_sub_pc_type lu
> -fieldsplit_boundary_ksp_monitor -ksp_monitor_true_residual
> -fieldsplit_interior_ksp_converged_reason". The splits are named
> "interior" and "boundary". The ksp output is as follows:
> Linear solve converged due to CONVERGED_ITS iterations 1
> This is the initial interior solve.
> Residual norms for fieldsplit_boundary_ solve.
> 0 KSP Residual norm 1.790059331071e-04
> 1 KSP Residual norm 1.237356212928e-04
> 2 KSP Residual norm 7.952220245101e-05
> Each iteration on the boundary problem requires an interior solve. We
> see alternating boundary residual and interior solves.
> [0] Petsc-Iteration 0: 0.574504
> You must be printing this somewhere.
> 0 KSP preconditioned resid norm 5.745043818120e-01 true resid
> norm 1.584249437360e-01 ||r(i)||/||b|| 1.000000000000e+00
> This is the norm of P^{-1} b, upon which all following norms are
> computed. Note that this is not actually a "preconditioned residual"
> because the initial guess was zero, however. In fact, since P is an
> exact preconditioner for your problem, it is the solution of your
> problem, but GMRES can't check that until it does one more iteration
> (the output below). You can use -ksp_type richardson to cheaply
> confirm that the norm is small, it should show a small residual after
> one iteration. Once you are happy that the inner solve really is
> solving your system, you can switch to -ksp_type preonly.
> 0 KSP Residual norm 1.790059331000e-04
> 1 KSP Residual norm 1.237356237744e-04
> 2 KSP Residual norm 7.952220078415e-05
> 3 KSP Residual norm 3.502859285561e-05
> 4 KSP Residual norm 1.601086485810e-05
> 5 KSP Residual norm 8.491169384185e-06
> 6 KSP Residual norm 4.778229157872e-06
> 7 KSP Residual norm 2.571917112191e-06
> 8 KSP Residual norm 1.353977280183e-06
> 9 KSP Residual norm 7.408352317360e-07
> 10 KSP Residual norm 3.810710583336e-07
> 11 KSP Residual norm 1.955898169394e-07
> 12 KSP Residual norm 9.938892788465e-08
> 13 KSP Residual norm 4.893428546840e-08
> 14 KSP Residual norm 2.395120857135e-08
> 15 KSP Residual norm 1.2464367927 <tel:1.2464367927>84e-08
> 16 KSP Residual norm 6.316409779118e-09
> 17 KSP Residual norm 3.088649355374e-09
> 18 KSP Residual norm 1.593449602302e-09
> The way GMRES computes residuals explains why we needed this Schur
> solve, but it shouldn't do the one below. Are you using GMRES or some
> other Krylov solver (perhaps set in an options file or inside your
> code, -ksp_view would help)?
> 0 KSP Residual norm 1.593449603155e-09
> 1 KSP Residual norm 1.011857676662e-09
> 2 KSP Residual norm 5.660892669788e-10
> 3 KSP Residual norm 3.046799343903e-10
> 4 KSP Residual norm 1.6004713993 <tel:1.6004713993>29e-10
> 5 KSP Residual norm 8.083216601016e-11
> 6 KSP Residual norm 4.308671648345e-11
> 7 KSP Residual norm 2.381959817139e-11
> 8 KSP Residual norm 1.264839790114e-11
> 9 KSP Residual norm 6.435098853282e-12
> 10 KSP Residual norm 3.184769579797e-12
> 11 KSP Residual norm 1.5022019430 <tel:1.5022019430>16e-12
> 12 KSP Residual norm 7.099486208425e-13
> 13 KSP Residual norm 3.443222176388e-13
> 14 KSP Residual norm 1.6478434989 <tel:1.6478434989>12e-13
> 15 KSP Residual norm 8.208508173926e-14
> 16 KSP Residual norm 4.376604355287e-14
> 17 KSP Residual norm 2.596069152755e-14
> 18 KSP Residual norm 1.335744434252e-14
> 1 KSP preconditioned resid norm 2.608069232839e-13 true resid
> norm 1.449869994655e-13 ||r(i)||/||b|| 9.151778504469e-13
> I have no idea how to interpret this output! Could you help me
> with it?
> Thomas
