[petsc-dev] Lagging the numerical factorization for one of the fields of fieldsplit preconditioner
Jed Brown jed at 59A2.org
Tue Mar 15 18:25:16 CDT 2011
On Wed, Mar 16, 2011 at 00:13, Barry Smith <bsmith at mcs.anl.gov> wrote:
> You cannot just check the row and column separately. You need to check them
> as a pair.  If row < m and column < n mark A as changed.
But you don't know what "A" is yet so all you can mark is some particular
pair (row,col) as changed. And you can't store cheaply in the form
(row_range, col_range) because you don't know when to extend an existing
range or when to create a new range. Maybe there is something clever that
works in a lot of common cases, but I don't think there is a cheap automatic
way to do this. I think you would have to declare index sets for submatrices
up-front.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110316/5940feb6/attachment.html>
