[petsc-dev] Lagging the numerical factorization for one of the fields of fieldsplit preconditioner
Jed Brown
jed at 59A2.org
Tue Mar 15 17:24:15 CDT 2011
On Tue, Mar 15, 2011 at 20:47, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Do you form the big-assed matrix
> > | A dg_dx |
> > | df_dy df_dx |
> explicitly as one big matrix? And each time-step you changes values in
> the dg_dx, df_dy and df_dx parts with MatSetValues?
> One fix may be to make PCSetUp() smarter and know the matrix has not
> changed and hence it doesn't have to be refactored (instead of only relying
> on the flag passed to KSPSetOperators()).
If you use MatNest (the logical choice with PCFieldSplit, it's a runtime
option except for preallocation), then we could PetscObjectStateQuery() to
decide when sub-objects need to be rebuilt. Seems like a better
general-purpose solution if you want an easy high-level way to control when
things get rebuilt.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110315/34c70b4b/attachment.html>
