[petsc-dev] Problem with SNES and FieldSplit
Matthew Knepley
knepley at gmail.com
Tue Mar 15 15:51:44 CDT 2011
On Tue, Mar 15, 2011 at 3:46 PM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, Mar 15, 2011 at 21:39, Matthew Knepley <knepley at gmail.com> wrote:
>> Here is the scenario. I have a FieldSplit solve with 4 splits. For the 4th
>> split, I have
>> a good preconditioner matrix. In the linear case, KSP, I am just doing
>> this:
>> err = KSPSetUp(_ksp);
>> err = KSPGetPC(_ksp, &pc);
>> err = PCFieldSplitGetSubKSP(pc, &num, &ksps);
>> MatStructure flag;
>> err = KSPGetOperators(ksps[num-1], &A, PETSC_NULL, &flag);
>> err = PetscObjectReference((PetscObject) A);
>> err = KSPSetOperators(ksps[num-1], A, _precondMatrix, flag);
>> err = PetscFree(ksps);
> Yuck.
>> which works fine. However, if we embed this in a nonlinear solve, so that
>> I now call
>> err = SNESGetKSP(_snes, &ksp);
>> <same code>
>> then the PC matrix for the 4th split is ignored. This happens because
>> SNESSolve_LS()
>> calls KSPSetOperators() right before the solve. This causes FS to pull out
>> the same
>> matrices again and overwrite my special PC matrix.
> The preconditioning matrix for this piece should be put into the global
> preconditioning matrix, perhaps stored as a MatNest. Fieldsplit should take
> that matrix apart for preconditioning and it'll find the preconditioning
> matrix for this part. More tricky is dealing with auxiliary operators such
> as appear in approximate-commutator Schur complement preconditioners. The
> current method is punting, you PetscObjectCompose the auxiliary matrix.
Really? That seems perverse. I have to build some global PC matrix, with
pieces I do not even have. How is that going to happen? Is
this really how we want to handle it? Also, I really need this to work now.
So baring some other idea, I am going to put something in
PETSc that lets me set this operator during the SNES loop.
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110315/11835b8d/attachment.html>
