[petsc-dev] DMDABoundaryType
    Ethan Coon
    ecoon at lanl.gov
    Mon Mar 14 09:43:29 CDT 2011
Ok, apparently etags does more than I thought it did... off to RTFM.
Ethan
On Mon, 2011-03-14 at 15:39 +0100, Jed Brown wrote:
> On Mon, Mar 14, 2011 at 15:34, Ethan Coon <ecoon at lanl.gov> wrote:
>         Related to this, do you guys have a standard way of finding
>         all such
>         instances?  I was using grep/find (and then checking the
>         compilation
>         output), but I'm sure my find was missing a few files.
> Depends on your editor, but there are "tags" for Emacs and Vim
> (slightly different in each case, but basically the same). Most IDEs
> have some sort of symbol-reference lookup functionality built in. You
> can also use GNU Global which retains a bit more information than the
> usual TAGS. I often end up using recursive grep to locate files with a
> certain property and then edit them using sed or perl -pi -e (for
> mechanical things). In addition to the tags searches, you can have
> Emacs visit every location that matches a grep query.
Ethan Coon
Post-Doctoral Researcher
Applied Mathematics - T-5
Los Alamos National Laboratory
505-665-8289
http://www.ldeo.columbia.edu/~ecoon/
