[petsc-dev] DMDABoundaryType
Lisandro Dalcin
dalcinl at gmail.com
Fri Mar 11 19:11:16 CST 2011
On 11 March 2011 20:35, Ethan Coon <ecoon at lanl.gov> wrote:
> Ok, here's a patch that makes the below change, and changes the APIs of
> DMDACreate*D(), DMDAGetInfo(), and DMDASetBoundaryType().
You missed a couple of fixes (pasted at the end). After applying your
patch, the updated (also working with petsc-3.1) petsc4py testsuite
pass fine.
> Nearly every tutorial/test example is touched, and everyone's DA code is
> broken. Up to you if you want it :)
> This should deal with Lisandro's c++ issue with int/enum bitwise or (or
> we could change the enum to a typedef if that works or int otherwise, or
> some other hack for c++?).
I vote for pushing your patch plus my trivial fixes... I think Barry
is still OK. Satish, do you what me to push? I'll use hg commit --user
"Ethan Coon <ecoon at lanl.gov>"
$ hg diff src/dm/impls/da/utils/binaryMatlab.c
src/dm/impls/da/ftn-custom/zdaviewf.c
diff -r e7b8783e37a0 src/dm/impls/da/ftn-custom/zdaviewf.c
--- a/src/dm/impls/da/ftn-custom/zdaviewf.c Fri Mar 11 15:21:12 2011 -0600
+++ b/src/dm/impls/da/ftn-custom/zdaviewf.c Fri Mar 11 21:57:20 2011 -0300
@@ -10,7 +10,7 @@
EXTERN_C_BEGIN
void PETSC_STDCALL dmdagetinfo_(DM *da,PetscInt *dim,PetscInt
*M,PetscInt *N,PetscInt *P,PetscInt *m,PetscInt *n,PetscInt
*p,PetscInt *w,PetscInt *s,
- DMDABoundaryType *wrap,DMDAStencilType
*st,PetscErrorCode *ierr)
+ DMDABoundaryType *bx,DMDABoundaryType
*by,DMDABoundaryType *bz,DMDAStencilType *st,PetscErrorCode *ierr)
CHKFORTRANNULLINTEGER(dim);
CHKFORTRANNULLINTEGER(M);
@@ -21,8 +21,10 @@
CHKFORTRANNULLINTEGER(p);
CHKFORTRANNULLINTEGER(w);
CHKFORTRANNULLINTEGER(s);
- CHKFORTRANNULLINTEGER(wrap);
+ CHKFORTRANNULLINTEGER(bx);
+ CHKFORTRANNULLINTEGER(by);
+ CHKFORTRANNULLINTEGER(bz);
CHKFORTRANNULLINTEGER(st);
- *ierr = DMDAGetInfo(*da,dim,M,N,P,m,n,p,w,s,wrap,st);
+ *ierr = DMDAGetInfo(*da,dim,M,N,P,m,n,p,w,s,bx,by,bz,st);
EXTERN_C_END
diff -r e7b8783e37a0 src/dm/impls/da/utils/binaryMatlab.c
--- a/src/dm/impls/da/utils/binaryMatlab.c Fri Mar 11 15:21:12 2011 -0600
+++ b/src/dm/impls/da/utils/binaryMatlab.c Fri Mar 11 21:57:20 2011 -0300
@@ -175,7 +175,7 @@
PetscFunctionBegin;
ierr = PetscObjectGetComm((PetscObject)viewer,&comm);CHKERRQ(ierr);
ierr = PetscViewerBinaryGetInfoPointer(viewer,&info);CHKERRQ(ierr);
- ierr = DMDAGetInfo(da,&dim,&ni,&nj,&nk,&pi,&pj,&pk,&dof,PETSC_NULL,PETSC_NULL,PETSC_NULL);CHKERRQ(ierr);
+ ierr = DMDAGetInfo(da,&dim,&ni,&nj,&nk,&pi,&pj,&pk,&dof,PETSC_NULL,PETSC_NULL,PETSC_NULL,PETSC_NULL,PETSC_NULL);CHKERRQ(ierr);
ierr = VecView(vec,viewer);CHKERRQ(ierr);
ierr = PetscFPrintf(comm,info,"%%--- begin code written by
PetscViewerBinaryMatlabOutputVecDA ---%\n");CHKERRQ(ierr);
ierr = PetscFPrintf(comm,info,"%%$$ tmp = PetscBinaryRead(fd);
\n");CHKERRQ(ierr);
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
