[petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
Lisandro Dalcin dalcinl at gmail.com
Thu Mar 10 16:58:26 CST 2011
On 10 March 2011 19:37, Ethan Coon <ecoon at lanl.gov> wrote:
>> > Will get patches for these (and the doc fix).
>> Could you also consider the patch below? I think the CHKMEMQ macros
>> should not be there, we are not calling "untrusted" user code, right?
> Oh crap, thanks, there's a bit more cruft that I thought I had removed.
>> And the missing free is causing the following output in petsc4py
>> testsuite:
>> $ python test/runtests.py -i da
>> [0 at nikola] Python 2.6 (/usr/bin/python)
>> [0 at nikola] PETSc 3.1.0-p7 development (conf: 'arch-linux2-c-opt')
>> [0 at nikola] petsc4py 1.1.2 (build/lib.linux-x86_64-2.6/petsc4py)
>> [0]Total space allocated 123685312 bytes
>> [ 0]10137008 bytes DMSetUp_DA_3D() line 1272 in
>> /usr/local/petsc/dev/src/dm/impls/da/da3.c
>> [ 0]1302848 bytes DMSetUp_DA_3D() line 1272 in
>> diff -r 3923fa35e382 src/dm/impls/da/da2.c
>> --- a/src/dm/impls/da/da2.c   Thu Mar 10 15:03:35 2011 -0600
>> +++ b/src/dm/impls/da/da2.c   Thu Mar 10 19:03:28 2011 -0300
>> @@ -1734,7 +1734,6 @@
>>    /*  ierr = PetscLogObjectMemory(da,nn*dof*sizeof(PetscInt));CHKERRQ(ierr);*/
>>    ierr = ISGetIndices(ltogis, &idx_full);
>>    ierr = PetscMemcpy(idx_cpy,idx_full,nn*dof*sizeof(PetscInt));CHKERRQ(ierr);
>> -  CHKMEMQ;
>>    ierr = ISRestoreIndices(ltogis, &idx_full);
>>    ierr = ISLocalToGlobalMappingCreateIS(ltogis,&da->ltogmap);CHKERRQ(ierr);
>>    ierr = PetscLogObjectParent(da,da->ltogmap);CHKERRQ(ierr);
>> diff -r 3923fa35e382 src/dm/impls/da/da3.c
>> --- a/src/dm/impls/da/da3.c   Thu Mar 10 15:03:35 2011 -0600
>> +++ b/src/dm/impls/da/da3.c   Thu Mar 10 19:03:28 2011 -0300
>> @@ -1273,7 +1273,6 @@
>>    /* ierr = PetscLogObjectMemory(da,nn*dof*sizeof(PetscInt));CHKERRQ(ierr); */
>> -  CHKMEMQ;
>> diff -r 3923fa35e382 src/dm/impls/da/dadestroy.c
>> --- a/src/dm/impls/da/dadestroy.c     Thu Mar 10 15:03:35 2011 -0600
>> +++ b/src/dm/impls/da/dadestroy.c     Thu Mar 10 19:03:28 2011 -0300
>> @@ -106,6 +106,7 @@
>>      ierr = AODestroy(dd->ao);CHKERRQ(ierr);
>> +  ierr = PetscFree(dd->idx);CHKERRQ(ierr);
>>    ierr = PetscFree(dd->lx);CHKERRQ(ierr);
>>    ierr = PetscFree(dd->ly);CHKERRQ(ierr);
>>    ierr = PetscFree(dd->lz);CHKERRQ(ierr);
> Hmm, I didn't add the dd->idx, so I'm suprised it wasn't free'd already.
> I also wasn't sure when/if to log the memory, since it seemed to be in
> there for some stuff and not for others in the previous code.
You should just log it in the DM object, just uncomment the line in
the 2D and 3D setup code
> With the copy (your next email) to the IS, shouldn't that changeset leak
> memory?  I think it also needs a PetscFree(idx) then as well...
My two patches are cumulative... Take into account that DMDestroy_DA
applies to 1/2/3D, while the setup code is different. The free(idx) at
the common destoy() should be enough (provided you use COPY_VALUES for
the 1D code)
> Will get these fixes in,
With both patches applied, petsc4py testsuite pass cleanly (and mem
leaks seems to go away). So I'm more or less confident on your (huge)
changes + my (tiny) fixes
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
