[petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
Lisandro Dalcin
dalcinl at gmail.com
Thu Mar 10 16:07:14 CST 2011
On 10 March 2011 18:55, Ethan Coon <ecoon at lanl.gov> wrote:
>> > What about renaming DMDAPeriodicType -> DMDABoundaryType ?
>> I like this suggestion. A patch to make this change can easily be generated.
> I'd considered this but wasn't sure if Barry would want to change the
> API when the rest of this doesn't affect any existing user code. It's
> definitely clearer with DMDABoundaryType. Should have known the
> answer ;)
>> Barry
>> > GHOSTED and
>> > PERIODIC are different concepts, the enumeration should have a more
>> > generic name.
>> > BTW, Why don't you?:
>> > +#define DMDAXPeriodic(pt) ((pt) & (DMDA_XPERIODIC ^ DMDA_XGHOSTED))
>> > instead of the hardwired value?
> No real reason. I'd done the algebra and had it written down that way
> in my notes, and added the comments as an explanation later. Will
> happily swap it since it's clearer.
OK.
> Will get patches for these (and the doc fix).
Could you also consider the patch below? I think the CHKMEMQ macros
should not be there, we are not calling "untrusted" user code, right?
And the missing free is causing the following output in petsc4py
testsuite:
$ python test/runtests.py -i da
[0 at nikola] Python 2.6 (/usr/bin/python)
[0 at nikola] PETSc 3.1.0-p7 development (conf: 'arch-linux2-c-opt')
[0 at nikola] petsc4py 1.1.2 (build/lib.linux-x86_64-2.6/petsc4py)
[0]Total space allocated 123685312 bytes
[ 0]10137008 bytes DMSetUp_DA_3D() line 1272 in
/usr/local/petsc/dev/src/dm/impls/da/da3.c
[ 0]1302848 bytes DMSetUp_DA_3D() line 1272 in
diff -r 3923fa35e382 src/dm/impls/da/da2.c
--- a/src/dm/impls/da/da2.c Thu Mar 10 15:03:35 2011 -0600
+++ b/src/dm/impls/da/da2.c Thu Mar 10 19:03:28 2011 -0300
@@ -1734,7 +1734,6 @@
/* ierr = PetscLogObjectMemory(da,nn*dof*sizeof(PetscInt));CHKERRQ(ierr);*/
ierr = ISGetIndices(ltogis, &idx_full);
ierr = PetscMemcpy(idx_cpy,idx_full,nn*dof*sizeof(PetscInt));CHKERRQ(ierr);
- CHKMEMQ;
ierr = ISRestoreIndices(ltogis, &idx_full);
ierr = ISLocalToGlobalMappingCreateIS(ltogis,&da->ltogmap);CHKERRQ(ierr);
ierr = PetscLogObjectParent(da,da->ltogmap);CHKERRQ(ierr);
diff -r 3923fa35e382 src/dm/impls/da/da3.c
--- a/src/dm/impls/da/da3.c Thu Mar 10 15:03:35 2011 -0600
+++ b/src/dm/impls/da/da3.c Thu Mar 10 19:03:28 2011 -0300
@@ -1273,7 +1273,6 @@
/* ierr = PetscLogObjectMemory(da,nn*dof*sizeof(PetscInt));CHKERRQ(ierr); */
- CHKMEMQ;
diff -r 3923fa35e382 src/dm/impls/da/dadestroy.c
--- a/src/dm/impls/da/dadestroy.c Thu Mar 10 15:03:35 2011 -0600
+++ b/src/dm/impls/da/dadestroy.c Thu Mar 10 19:03:28 2011 -0300
@@ -106,6 +106,7 @@
ierr = AODestroy(dd->ao);CHKERRQ(ierr);
+ ierr = PetscFree(dd->idx);CHKERRQ(ierr);
ierr = PetscFree(dd->lx);CHKERRQ(ierr);
ierr = PetscFree(dd->ly);CHKERRQ(ierr);
ierr = PetscFree(dd->lz);CHKERRQ(ierr);
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
