[petsc-dev] Using PCFieldSplitSetIS
    Thomas Witkowski
    Thomas.Witkowski at tu-dresden.de
    Wed Mar  9 13:50:11 CST 2011
As I already asked on petsc-users, I want to implement some kind of
iterative substructuring algorithm in my fem code. It was suggested to
me to switch to the dev version of petsc and to make use of
PCFieldSplit. So far I have installed petsc-dev and read a little bit
about the PCFieldSplit. It sounds great. But I'm not really sure how
to make use of. In my code I want to build n blocks (where n is also
the number of processors), each for the interior domain of one rank.
Okay, this seems to be easy. I make just one call to PCFieldSplitSetIS
on each rank with IS being the global indices of the ranks interior
nodes. But what about the n+1 block, which should contain all the
nodes of the boundaries between the subdomains? Each rank contributes
to this block. So how show PCFieldSplitSetIS should be called? May be
some small example: Assume we have two ranks, each with 100 nodes in
its interior domain and each rank contributes with 10 nodes to the
interior boundary (so the overall interior boundary contains 20
nodes). So rank 0 owns global indices 0 to 109, with 100 to 109 being
the nodes of the first part of the interior boundary), and rank 1 owns
global indices 110 to 219, with 210 to 219 being the nodes of the
second part of the interior boundary. When I understood the idea
behind PCFieldSplit correctly, it should be possible to generate the
three blocks [0-99],[110-209],[100-109,210-219] using
PCFieldSplitSetIs. But how to call it correctly?
Thomas
